Results 1 to 6 of 6
Thread: Residential Water Line 1200'
    DIY Junior Member
    Jun 2013
    South Carolina
    Default Residential Water Line 1200'
    I need to install a 1200' service line from the meter for a new home that we are building. Not much, if any, change in elevation in that distance. I have several questions and would appreciate any advice. Thanks!
    1) Size and type of pipe? I have installed plenty of PEX inside homes but have never done a service line. 3/4", 1", or larger to reduce friction loss? Obviously don't want to spend more for larger pipe for little or no benefit. I don't anticipate rocky soil, but would the cost for smooth gravel, sand, or sleeving be worthwhile to protect the pipe underground?
    2) Utility has offered a 5/8" meter. Is there any benefit to requesting a 1" meter? I think that would only help with volume, not pressure?
    3) Should I install disconnects every few hundred feet to help locate and repair any future leaks?
    DIY Senior Member DougB's Avatar
    Jun 2010
    Minneapolis - Land of 10,000 taxes
    http://www.engineeringtoolbox.com/pr...pes-d_404.html
    I'm not a well driller, just an engineer. That's a long run 1/5 of a mile. No reason to guess - get a pro to size this.
    If a hammer won't fix it, it's an electrical problem.
    Water pipe sizing
    The link is just a partial chart, and I can't see you using less than 1.5", and maybe 2.0" would be better.
    Default pipe
    I might consider 1 1/2" polyethylene because it comes in 500' rolls.
    Friction is your enemy here...larger is better.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    I think Oli Creek makes 2" in 1000' rolls, yep it's gonna be a pain to work with. I would someone who does geo thermal work to fuse on transitions that go from the poly to pipe thread, especially in the trench.
  1. Identifying Cartridge, Moen 1200
    By kalisti in forum Shower & bathtub Forum & Blog
    Last Post: 05-06-2012, 05:18 PM
  2. Moen 1200 cartridge - can I just replace the rings??
    By nards01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2012, 05:14 AM
  3. new 1200' polyethylene water line questions
    By klwinter2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-16-2011, 01:28 PM
  4. 670' residential water line. What size should I use
    By OHIOresident in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2010, 07:36 AM
  5. Need help identifying a Moen 1200 shower valve/cartridge
    By sproksch in forum Shower & bathtub Forum & Blog
    Last Post: 04-22-2010, 12:21 PM
