Results 1 to 9 of 9
Thread: Iron pre-filter for RO
Hybrid View
    DIY Junior Member OldBat's Avatar
    Jun 2013
    North Ga US
    Default Iron pre-filter for RO
    Hi, new here. On a drilled well and have suffered with clear water iron >5PPM plus iron bacteria for years. Simple filters are not effective and every time I have researched something that might work it was cost prohibitive.
    Was recently given a 5 stage with RO for just drinking water. Have it mostly installed but not hooked up yet because iron is one of the few things it can not handle. While the manufacture recommends an iron pre-filter they will not recommend a *specific* one since they do not sell them... Argh!
    Want to avoid the expense of any thing whole house so what are my options? Will a washable ceramic be enough? Do they make a tiny softener system that can handle iron that high? Currently buying an average of 3 1/2 gallons per day for drinking and cooking, so 1 gallon per hour should still be plenty even with the RO wasting 2 gallons for every 1 produced.
    Nov 2010
    Maine
    Chlorene injection
    Jan 2012
    California
    When was the last time you had the water tested? Can you post those results? Otherwise we are just wild guessing. Tom hit it right with Chlorine injection to start. But what to do after that?
    FYI, RO's do not typically run at a 2:1 ration, depending on the system design, 4:1 - 8:1 is more common. If you are running at a 2:1 ratio, the water should be carefully pre-treated or you will be replacing membranes regularly.
    Jun 2013
    North Ga US
    Thanks both! Searching for "chlorine injection" and not liking what I have found so far. Complete systems that are way over my budget and components that are not specked in a friendly to DIYSers way. Will keep searching...
    Last professional test was long ago. Just ran a cheep kit a few days ago to re-confirm what we have know for almost 20 years. Iron is off the scale and a few other minor issues that are trivial to fix.
    The 2:1 ratio is from the RO filters literature. Have not started using it yet so can not confirm. None of the reviews, even the negative ones, mentioned this so I have to take their word.
    Nov 2005
    Central Florida
    Check this online vendor's "Complete Guide to Home Chlorination Systems" at http://www.cleanwaterstore.com/chlorinator.html. It's a pretty comprehensive, step-by-step guide to choosing a chlorinator system. It's got some prolems:
    1) They sell Stenner injection pumps, which some pro's like, others don't;
    2) They suggest injecting the chlorine before the pressure tank, which some pro's like, others don't;
    3) They say you can't use bleach for the chlorine solution, but that's not true for Clorox brand;
    4) They show a carbon filter (required as part of the system) in their illustrations, but don't give much detail. There are many discussions of carbon filters on this forum.
    And, of course, the cost problem remains, but you get what you pay for.
    Nov 2010
    Maine
    Yea, unfortunately there is no cheap way out of treating IRB and clear water iron and both will mess the RO filter up in short order.
    DIY Senior Member lifespeed's Avatar
    Apr 2007
    California
    It sounds like you have a significant iron problem. Unfortunately, while there are many good solutions to iron that may be tailored to your specific situation, you will not find a *true* solution for cheap. I would estimate $1 - $1.5K.
    Lifespeed
  1. Iron Filter Spews Iron after Outdoor Sprinklers are ran
    By branjo101 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-30-2011, 12:13 PM
  2. Help w/iron H2S filter
    By Nat in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-18-2011, 04:26 PM
  3. New home / iron filter
    By leslie B in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-12-2010, 03:37 PM
  4. Iron Filter questions
    By djd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-19-2008, 09:56 AM
  5. iron filter drain
    By rburt5 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2008, 11:50 AM
