Results 1 to 2 of 2
Thread: Kitchen Sink On, No Heater Firing. Rest of House Fixtures Fine.
    Plumber MichaelBukay's Avatar
    Jan 2013
    San Diego, California
    Default Kitchen Sink On, No Heater Firing. Rest of House Fixtures Fine.
    So I have sort of an odd problem. This house I was working on doesn't get hot water in the kitchen. The tankless is a Noritz N069-M. Every other fixture in the house, when the hot water draws, fires the heater. Yet the kitchen does not. I didn't install the heater, or any of the piping, I was just asked to take a look at the problem. I'm at a loss. The kitchen is about 40' from the heater, and the bathrooms are within 5'-10'.
    In the trades Dana's Avatar
    Jan 2009
    What's the flow rate like at the kitchen, and is it a mixer valve (likely)? Did it ever work properly at the kitchen sink?
    There is a min-flow requirement to get the tankless to light-off- cracking it open at a dribble won't cut it, even if once it lights it can be taken down to a fairly low flow without flaming out. Min-flow on the N069-M is 0.5 gpm- below that it can't light, or will turn off. If the mixer at the kitchen is defective and only delivering cold or not enough flow on the hot side, that could cause the symptom.
    Turn off the shutoff valve to cold side of the mixer, see if that affects the total flow when the mixer handle swung all the way to "hot", &/or the ignition issue.
  1. Low Bathtub Pressure? The rest of the house has great pressure.
    By adayinthelife in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-27-2010, 03:50 PM
  2. No water pressure in one tub, rest of house fine
    By lbet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2008, 11:00 AM
  3. Tankless alternative for Master Bath? (Marathon for rest of house)
    By dixiedoodle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2007, 08:48 AM
  4. Water Heater Relief Valve firing intermittently
    By GregN31 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2005, 07:52 PM
  5. tub won't drain, other fixtures are fine...
    By plumbbob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2004, 08:32 PM
