Thread: Winterizing my softener
    DIY Junior Member dunkinidaho's Avatar
    Aug 2009
    Michigan, USA
    Default Winterizing my softener
    We live in florida in the winter and are wondering if there is anything we should do to our softener for this time. Usually we just turn off the water at the well and leave. When we get home in the spring I run it through two cycles.
    thanks
    Nov 2010
    Maine
    Sounds like a good plan to me. Don't drain it whatever you do.
    Jan 2012
    California
    It would not hurt to sanitize it if it sits without water flow for extended periods of time. A little bleach in the brine tank before you regenerate is all that is needed.
    Chlrione will damage resin over time, but it is a cumulative equation. Intermittent sanitizing will not have any real long term negative affects on the resin.
    Aug 2009
    Michigan, USA
    thanks for the advice
  1. Winterizing Question
    By BrianC in forum Tankless Water Heater Forum
    Last Post: 09-10-2013, 01:00 PM
  2. Winterizing Water Softener
    By chuck b in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-09-2011, 09:10 AM
  3. Winterizing - other than pipes ??
    By kstuart in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-08-2010, 10:07 PM
  4. Winterizing well
    By Elinger in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-28-2008, 06:09 AM
  5. Winterizing question
    By martin1b in forum Irrigation / Sprinkler Forum
    Last Post: 05-24-2007, 08:47 AM
