Results 1 to 5 of 5
Thread: Neorest 500 and Rough-in Question
    DIY Junior Member herao's Avatar
    Jun 2013
    California
    Default Neorest 500 and Rough-in Question
    My existing toilet has a rough-in of about 11 inches. Will a Neorest 500 install without altering the wall behind the 500 position? Alternatively, we're looking at a Vespin II (with 10 inch kit) and an S350 Washlet.
    Thanks.
    I've installed the Neorest 500 at 11.5" from the back wall.
    Are you measuring the wall? Or the floor mold?
    You can also fudge the adaper away from the wall some, depending on the size of your floor drain.
    On 3" you can pick up 3/8", and more on a 4" .
    Jun 2013
    California
    11 inches from the floor baseboard and 11.5 inches from the wall.
    Bob
    Apr 2012
    New York, NY
    Just FYI, you can probably get away with the standard 12" Unifit on the Vespin II if you have 11.5 to the finished wall, even if you only have 11 to the baseboard, but check on here where Terry lays out what you need for that model. I know the 11.5 to the finished wall isn't a problem; I'm just questioning the 11 to the baseboard. You generally have 3/4" behind the tank at 12", and the base is out forward from the tank -- I'm almost certain the extra 1/4" won't be a problem, and you can always fudge the Unifit a bit.
    With 11.5" to the wall you're fine with either the 500 or the Vespin II with their standard 12" kits.
  1. Neorest 500 wand extension question
    By anevesma in forum Toilet Forum discussions
    Last Post: 01-09-2013, 01:40 PM
  2. Toto Neorest 500/550/600
    By zelpheri in forum Toilet Forum discussions
    Last Post: 04-18-2012, 08:50 AM
  3. Toto Neorest 600 installation question
    By pmurali in forum Toilet Forum discussions
    Last Post: 03-28-2010, 04:38 AM
  4. NeoRest 500 Questions
    By cclearly in forum Toilet Forum discussions
    Last Post: 10-27-2008, 12:11 PM
  5. What's the difference between the Neorest 500 and 600?
    By Meno in forum Toilet Forum discussions
    Last Post: 08-07-2008, 09:53 AM
