Hi everyone, i had a previous thread where you all helped in my new toilet decision and i ended up ordering a TOTO CST454CEFG-01 Drake II 2-Piece Toilet. I read most of the reviews on the toilet. One bad review was from someone that received the toilet and apparently there was a crack in the p-trap. According to the review this is common and you can't see the crack from visual inspection. I would guess even if it was one you bought locally and installed by a plumber then the plumber wouldn't even know there was a crack if there was one. Course the only advantage of getting one locally would be returns.
So my first question is if there is any way to test the toilet to ensure there isn't any cracks like this that wont' be visible other than possible a sewer gas leak that you would probably smell sometime later?
2nd question is i bought Non-wax type toilet seal: http://www.fernco.com/plumbing/wax-free-toilet-seal There is a 3, 4, or 5 in seal. Apparently the 3 is the most common. Is there anyway to ensure i bought the correct seal other than pulling up the toilet? My house was built in the mid 90s. As far as i can tell its a pretty standard toilet (12 in from the wall).
thanks...
thanks...
