Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: dripping in the fire sprinkler system
  1. #16
    DIY Junior Member Mark Potter's Avatar
    Jul 2013
    NY
    Oh boy guess you guys aren't licensed fitters. I know for a fact in my location you can not use copper or pex from main to the heads. And you also need permits and inspections on the installs.
  2. #17
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    No I am not a fitter however I am a licensed fire sprinkler master installer since Jan 1989,
    Yes you need permits and inspections ever where on new construction how ever this is an existing installation,
    and as such only needs to be recertified once a year or as local code requires
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  3. #18
    Jul 2013
    NY
    Quote Originally Posted by MACPLUMB 777 View Post
    #1 Mark Potter you need to stop posting about something you know nothing about !
    #1 House fire sprinklers do come off the same water meter and supply as the house,
    #2 Both copper and pex are accepted for fire sprinkler systems,
    #3 As to what was posted earlier almost all new home systems are piped with pex in a circle fashion for both potable water and the sprinkler use,
    I am aware of residential systems being installed this way were every thing is looped from sprinkler back to fixture and vice versa, IMO it's not method in which is better.
  4. #19
    Yakima WA
    You know all of this arguing back and forth is pointless. As I stated way back when: this is not a DIY job. The man needs a licensed fire installation person to fix this problem and it doesn't make squat what the problem is.
  5. #20
    Aug 2007
    Quote Originally Posted by gary swart View Post
    you know all of this arguing back and forth is pointless. As i stated way back when: This is not a diy job. The man needs a licensed fire installation person to fix this problem and it doesn't make squat what the problem is.
    Exactly Gary thank you, my point
    MACPLUMB 777
    E-MAIL
  1. fire sprinkler main and backflow devise.
    By LBJAMES in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-22-2011, 06:25 AM
  2. House Fire Sprinkler
    By Master Brian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-20-2008, 01:43 PM
  3. Need Help with Fire Sprinkler system
    By DonM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-27-2007, 03:35 PM
  4. Replacing fire suppression sprinkler heads...
    By tista in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-31-2006, 05:34 AM
  5. fire sprinkler pressure tank(s)
    By twigpig in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-12-2005, 06:40 AM
