Results 1 to 2 of 2
Thread: By pass plug {suntec pump}
    DIY Junior Member w kern's Avatar
    Jun 2013
    central pa
    Default By pass plug {suntec pump}
    I want to add the two pipe system to my oil burner, bought the by pass plug,1/16 for a A pump,should it have a 1/16 hole ?
    DIY Member
    May 2012
    Brooklyn, New York, United States
    to convert to 2 pipe system, remove return port plug and install by pass plug, then connect return line, shut off valve on return line must not be installed.
  1. Will this pass code in Texas
    By oldbridge40 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-22-2012, 06:57 PM
  2. Replies: 3
    Last Post: 11-02-2011, 12:52 PM
  3. Suntec A2VA-7116 leaking?
    By TeePeeB in forum HVAC Heating & Cooling
    Last Post: 06-02-2011, 04:17 PM
  4. To plug or not to plug into a GFCI outlet
    By DIY in forum Electrical Forum discussion & Blog
    Last Post: 04-15-2009, 04:13 PM
  5. Snoqualmie Pass 1958
    Last Post: 04-04-2009, 12:31 PM
