Thread: Water Heater Recirculating Pump
    Home inspection LoydDobbler's Avatar
    Mar 2013
    New Mexico
    Default Water Heater Recirculating Pump
    My main trade is a home inspector. Friday's house had a re-circ pump on the hot water tank. Instead of the usual setup with a return line, this pump was simply installed on the hot water output line. My main thought is that this is not going to work very well. It seems like it would just be pushing to a dead end instead of actually recirculating anything. Just looking for anyone who may have run across this before. I can't see how it would work. There were no check valves, so the other thought is that it would push hot water out of the cold water side, but I'm not even sure how that would happen. The pump was not in use, and the house was not occupied at the time of the inspection, so I was not able to check it out under normal use circumstances.
    This type of system typically uses a thermostatically controlled cross-over valve (at least one, maybe multiple) in the house, often under the sink of the furthest away item. So, if you didn't look underneath each fixture, you probably missed it. That cross-over may have a checkvalve installed in it. While a dedicated return line is probably the best, the retrofit type that uses the cold line for the return is fairly common.
    Mar 2013
    New Mexico
    Good thought. I rarely see a cross over valve, but I do know what you're talking about. I've seen one in 1,500 houses here. I'm pretty sure there isn't one under any of the sinks, because I do look under each sink, but it is a good point to ask the sellers about. This is an estate sale, so we don't have a lot of knowledge about the house available. For all I know, they meant to put one in some day, and never got around to it. It's a good thought for my client though, and may make the pump a usable system at not much of a cost. They are planning on some significant remodeling anyhow.
  1. Another question on recirculating pump - how to connect to water heater?
    By CountryBumkin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-12-2013, 09:50 AM
  2. Recirculating pump not working after water heater replacement
    By Mmonagan in forum Water Heater Forum, Tanks
    Last Post: 01-13-2013, 11:54 AM
  3. No recirculating hot water after water heater installation - photos
    By KarenS in forum Water Heater Forum, Tanks
    Last Post: 08-05-2012, 09:18 AM
  4. Dual water heaters with recirculating pump
    By LeonUGA in forum Water Heater Forum, Tanks
    Last Post: 05-28-2009, 06:51 PM
  5. Water heater recirculating question
    By Cass in forum Water Heater Forum, Tanks
    Last Post: 05-22-2009, 09:02 AM
