Results 1 to 5 of 5
Thread: Crimp off soft copper
    DIY Senior Member DougB's Avatar
    Jun 2010
    Minneapolis - Land of 10,000 taxes
    Default Crimp off soft copper
    I have hydronic heat. There is a loop of 1/2" od soft copper embedded in the mud of the bathroom floor. I'm going to rip out the mud (it's cracked) and install a new subfloor.
    I do not want to drain the entire system. However I have released the water pressure
    in the boiler.
    I would like to crimp the tubing, cut it off and sweat on a fitting to permanately seal the
    tubing.
    Do you think a large C-Clamp would be sufficient? Any other ideas?
    If a hammer won't fix it, it's an electrical problem.
    Jun 2010
    Well a C-Clamp and vise grips were enough to stop it down to a drip - but not enough to solder. Had enough room for a flare block - so I flared it and that worked!
    Nov 2006
    Quote Originally Posted by DougB View Post
    Cool beans. I had thought about suggesting that, but was unsure about burying a threaded fitting,
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    Default copper
    I was going to say that if you turned off the pressure, all you had to do was drain the water below the level of the tubing. Does your description mean that the "crimp off" is still on the copper behind the cap?
    Jun 2010
    The problem is that I have hydronic heat in the ceilings of my home - there are 1000's of feet of 1/2" od soft copper embedded in the plaster ceilings. It's a real pain to get the air out, so I didn't want to drain the circuit.
    So, in the lower level ceiling, I used a C-clamp and vise grip to close off the 'loop' in the bathroom floor. I cut the copper about 6" before the crimp. The crimp was effective - just a dribble or two of water. That's when I decided to flare the tubing and capped one end of a flare-to-pipe union for a stopper.
  1. What tool to use to crimp PB fitting? What color crimp rings do I use?
    By CountryBumkin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-17-2012, 07:26 AM
  2. copper crimp pex tool
    By kadimkris in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-30-2011, 10:31 PM
  3. 5/8 in Soft Copper
    By Livi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-13-2009, 08:50 AM
  4. soldering soft copper
    By scott99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2007, 03:13 PM
  5. PEX or Soft Copper
    By RRG75 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-26-2006, 05:51 AM
