Thread: Help - what is this pipe coming through the foundation?
    DIY Junior Member TwinsFan's Avatar
    Jun 2013
    MN
    Default Help - what is this pipe coming through the foundation?
    Hello, I came across this forum because I have a problem. We are currently having a bit of a heavy rain and I heard water running from behind my furnace. I'm posting this here because of the location of my problem but if this is the wrong forum, I apologize. The source of the leak is pipe that is a little less than an inch in diameter coming through the foundation right under my furnace vent. I had never noticed it before but water is coming in pretty good. Does anyone have any idea what this is? And how I might fix the problem?
    Name:  Photo Jun 15, 3 43 19 PM.jpg
    Name:  Photo Jun 15, 3 44 00 PM.jpg
    Jan 2008
    Is that the chimney or the basement wall?
    Jun 2013
    MN
    Thanks for the reply. I guess it's the chimney. It's the exterior of the basement but the trap door deal where they used to let the ash drop from the fireplace is right below where the picture ends. Fireplace is directly above on the main floor. My hot water heater and furnace vent out right above the leak.
    Jan 2008
    Without some investigation I could only guess that someone installed the pipe to prevent rainwater from accumulating in the chimney.
  1. How to bring water into a slab foundation. The concrete is coming Thurs!!!
    By MaxBlack in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-21-2012, 10:22 AM
  2. Copper pipe through concrete foundation
    By tedf in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2011, 02:51 PM
  3. old pipe hole to fill in, block foundation
    By rmeagher in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-27-2008, 02:50 PM
  4. Removing waste pipe from foundation wall
    By patrick0042 in forum Toilet Forum discussions
    Last Post: 11-21-2006, 09:12 AM
  5. hydraulic cement - foundation leak - supply pipe
    By dave007 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2006, 09:42 AM
