Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Water Hammer wont go away
  1. #16
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Valveman, interesting that you say the air doesn't get absorbed in the risers. I would think the riser would be like a small hydro pneumatic tank and it would absorb the air pocket.
  2. #17
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    With a riser, the water doesn't flow in one side and out the other like it does in a hydro tank. Risers tend to accumulate air like the high spots in an irrigation line.
  3. #18
    Maybe if you're on a well system you might have a lot of entrained air in your water, but a typical municipal pumped system does not have much air in it, and the water sloshing into the riser is MUCH more likely to absorb air than to leave some there! There's a good reason why engineered arresters were designed...they work if they're in the right position and sized properly for a long time.
  4. #19
    DIY Senior Member wallygater's Avatar
    Dec 2007
    long island
    Default some answers
    Okay, lets backup here. Water hammer occurs when the water is shut off, not during, or when the water is turned on. Is it actually ONLY making the noise when the WM turns off the water? Is it more than one bang? Does it happen EVERY time the WM turns the water off? Does it make noise if you set to only use cold, or only when hot is being used? Can you see the pipes moving when this occurs? Did you anchor anything? Unless you destroyed the arresters when you soldered them in, they generally solve the problem IF it is truly a WM related water hammer. It's hard to diagnose without being there.
    ONLY making the noise when the WM turns off the water? YES
    Does it happen EVERY time the WM turns the water off? YES
    make noise if you set to only use cold, or only when hot is being used? COLD YES, (HOT JUST A LITTLE)
    Did you anchor anything? NO
    Can you see the pipes moving when this occurs? NO
    wally
  1. Water Hammer & Water Hammer Arrester location
    By amkazen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2013, 09:26 PM
  2. Replies: 2
    Last Post: 07-10-2012, 04:19 AM
  3. Ace in Hole works, but wont discharge any water when connected as backup
    By kezug in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-28-2011, 10:54 AM
  4. Reliant WH wont keep the water hot!
    By ninefall in forum Water Heater Forum, Tanks
    Last Post: 10-13-2009, 09:43 PM
  5. shower water wont turn off
    By asuss06 in forum Shower & bathtub Forum & Blog
    Last Post: 07-05-2009, 10:36 AM
