Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Thread: Three Dead Outlet Mystery
  1. #16
    A pro might use something like shown here: http://www.licensedelectrician.com/S...FQug4Aod0EcAcQ There are some cheaper, less capable versions and something like this might help http://www.homedepot.com/p/Klein-Too...0#.UcEPuSvD-Cg.
  2. #17
    DIY Senior Member wallygater's Avatar
    Dec 2007
    long island
    thats a petty good idea. thanks
    wally
  3. #18
    Dec 2007
    long island
    at least it would narrow it down a bit
    wally
  4. #19
    Dec 2007
    long island
    no matter what i do, the 4 dead outlets will remain dead even with the beaker off
    it will still be hard to determine wich breaker/circut it is
    But, it might help to narrow it down a bit
    wally
  5. #20
    Jun 2007
    North Carolina
    Once again I say
    Quote Originally Posted by jwelectric View Post
    It is now time to call someone who knows what they are doing before you either get hurt of burn your home to the ground
  6. #21
    At least you could quickly determine where all of the working circuits go, which may narrow it down some. Sometimes, a good visual inspection is all it takes. If there's a broken wire somewhere in the wall, or say one that got punctured by a nail or similar, it's harder to trace. I'd first remove the wires from the load side of the GFCI, and verify that the GFCI doesn't start to work. If everything downstream from the GFCI is not working, I'd definitely start there! You never did verify that you pressed the reset (it should click going in if it is tripped), and the test button actually does something. That receptacle will NOT work if it is either defective or tripped. I had an intermittent connection that gave me fits...I isolated it as a run between two receptacles on the chain. I eventually just ended up running a new cable, since I wasn't going to tear the walls apart to find out what the problem was in between.
  7. #22
    Dec 2007
    long island
    ok. i got rid of the GFI and put a regular outlet in that box for now. i tested the wires again and there is definatly no juice at that box or the other three.
    I am going to buy the thig at HD friday.this thing
    i will post the results
    wally
  8. #23
    Dec 2007
    long island
    Once again I say
    i am being carefull, thank you
    wally
  9. #24
    Jun 2007
    North Carolina
    Quote Originally Posted by wallygater View Post
    This is exactly what everyone who ever got hurt said. My question is a simple one, “how can one be careful doing something they know nothing about?”
    I suppose all those who got blown up trying to disarm one of them explosive devices over the ocean was being careful also.
    By your post you are showing that the one thing you aren’t doing is being careful so please get someone to help you before you end up hurt of dead
    I turned off the whole house, left one circut on that I know is independant (Bathroom), ran power into the (last outlet)
    whats inceadibley confusing is one of the bare wires was also energized. the other bare wire had no reading.
    See what I mean? If the whole house was off except the bath circuit there is no way that one bare wire would be energized.
    Now get help please before we read about you in the paper and those hungry young'uns are running around without a daddy
  10. #25
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    I am with JW on this, time to call in a pro!
  11. #26
    Oct 2011
    Stop testing for juice and test for voltage. Maybe that is the problem. No type of juice: apple, orange, pomegranate, hillbilly..etc... should be near the wires.
  12. #27
    Oct 2011
    Why would you have to put another receptacle in the box, all you had to do was test the wires for voltage. If there is none at the location of this GFCI, go one device upstream of that and check there for voltage. By going one device upstream I mean go to wherever the GFCI is being fed from.
  13. #28
    Mar 2011
    Houston, TX
    I like sparking and arcing, but that was a bad Idea, for your application.
    If you do not have a way to check the voltage on a wire then you should not just change parts, or stab in the dark.
    The GFI is for your protection and safety.
    Be careful playing with electricity.
  14. #29
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    I love being a dyed in the wool DIY guy myself, but I am going to have to side with JWElectric and others on this one. For all the time you've invested in this, not to mention buying whatever tool you are planning to buy at HD (link isn't working for me), you could probably have gotten an electrician out to the house, had the thing diagnosed, and fixed long before now.
    I would bite the bullet, hold your nose, do whatever kind of thing you need to do to get over your reluctance to hire a pro, and pick up the phone.
  1. HELP: gerber 21-374 floor mount back outlet bowl waste outlet thickness
    By munkyboi in forum Toilet Forum discussions
    Last Post: 01-29-2013, 02:22 PM
  2. Replies: 9
    Last Post: 12-11-2012, 12:01 PM
  3. Is the duck dead?
    By Cookie in forum Health and Wellness Forum
    Last Post: 04-11-2011, 04:41 PM
  4. convert NEMA 6-20R outlet to standard 110 outlet?
    By cham33 in forum Electrical Forum discussion & Blog
    Last Post: 08-16-2010, 02:27 AM
  5. Replies: 9
    Last Post: 07-18-2008, 07:16 PM
