Results 1 to 3 of 3
Thread: Alternative for hose bib vacuum breaker noise
    DIY Junior Member DIYER39's Avatar
    May 2013
    Spring Valley, CA
    Default Alternative for hose bib vacuum breaker noise
    I recently installed hose bib vacuum breakers that I bought from my local home improvement store for $5. They create a ton of noise in the pipes when using the spray nozzles. It even sounds like the pipes shake a little inside the wall. I also dont know if that noise causes wear and tear on the pipes since my wife gardens everyday 365 days of the year. After doing my research on google I noticed that this was a fairly common problem with vacuum breakers and relates to the spray nozzle opening and closing constantly. Obviously there is no noise from pipes when water flow stays on or water flow stays off. I would like to keep using the spray nozzles for gardening, washing cars, things like that because it would really be a pain to always have to walk back and forth turning the valve on and off. Can someone please recommend an alternative or let me know if I am doing something wrong. I want to just throw the vacuum breakers in the trash but I worry about my families safety. Ive included a few pictures for reference.
    Is there a better alternative that I dont know about? Maybe a different type of backflow device.
    Am I just using cheap vacuum breakers?
    Is all this pipe noise something that I should just be ignoring and not harmful to pipes?Name:  DSC_8878.jpg
Size:  33.3 KBName:  DSC_8879.jpg
    May 2013
    Spring Valley, CA
    Anyone? Am I just stuck with the pipe noise and shaking?
    WE install hose vacuum breakers every day, and our customers do NOT have that problem, so the obvious answer is that the problem is that particular brand of BFP.
  1. Pressure vacuum breaker making noise
    By joeslppy in forum Irrigation / Sprinkler Forum
    Last Post: 09-09-2009, 07:11 AM
  2. Hose Vacuum Breaker Removal & Replacement
    By knuckle buster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2009, 06:28 AM
  3. Help with vacuum breaker
    By Mel in forum Irrigation / Sprinkler Forum
    Last Post: 08-22-2006, 08:41 AM
  4. Sprinkler Air Vacuum breaker vs Pressure vacuum breaker
    By Mike Pascutiu in forum Irrigation / Sprinkler Forum
    Last Post: 05-28-2005, 01:47 AM
  5. Sprinkler Air Vacuum breaker vs Pressure vacuum breaker
    By Mike Pascutiu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-27-2005, 08:28 AM
