Results 1 to 2 of 2
Thread: Subpanel
    DIY Junior Member alvaradso626's Avatar
    Jun 2013
    La Puente Ca L.A. County
    Default Subpanel
    Hi There new guy here well I'm trying to add a sub-panel thing is my sub panel neither my house r. grounded House was build in 1955 Sub panel does not have a ground bus to b connected too
    Main panel has whats call bull dog or push in breakers Where should I connect the ground in the sub panel Thank u
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    There is likely a bare wire from the neutral bus going to a water pipe (and possibly a ground rod) somewhere, and possibly to the kitchen and bathroom outlets. The neutral bar in the bulldog panel serves as a ground bus also.
    My 1960 house in Santa Clara had a bare #8 copper wire running under the stucco to the nearest water spigot -- very difficult to find.
    When you are done, there should, at a minimum, be un-spliced ground wires from the main panel to both the underground water service pipe and a ground rod, or two ground rods if the water pipe is not metal.
    You'll need both a ground and neutral wire running between the main panel and sub-panel. In the sub-panel, the neutral bus must not be bonded to the panel and ground bus. Have you considered upgrading your panel? The bulldog/pushmatic stuff is dated and considered a fire hazard by many (mine is long gone!!!).
    What I mentioned here is not everything you need to know to do what you are talking about -- just the beginning. Please make sure you take the time to really learn this stuff well before doing any work. Do a lot of reading, ask for help, and be careful. I would strongly consider having an experienced electrician (not a handyman) do/supervise the work. You are getting a permit and inspections, right?
  1. 100 Amp Subpanel
    By tsingerjr in forum Electrical Forum discussion & Blog
    Last Post: 06-10-2012, 01:53 PM
  2. Subpanel
    By Farmhouse1890 in forum Electrical Forum discussion & Blog
    Last Post: 05-04-2012, 10:48 PM
  3. Max CB for SubPanel
    By Ted M in forum Electrical Forum discussion & Blog
    Last Post: 01-20-2012, 05:10 AM
  4. 6 AWG to 100 amp subpanel?
    By seattle_steve in forum Electrical Forum discussion & Blog
    Last Post: 11-23-2011, 12:56 PM
  5. Subpanel
    By benr in forum Electrical Forum discussion & Blog
    Last Post: 09-07-2007, 07:07 PM
