Page 9 of 22 FirstFirst 12345678910111213141516171819 ... LastLast
Results 121 to 135 of 326
Thread: Toto Drake toilet product review
  1. #121
    DIY Junior Member oneilljf's Avatar
    Feb 2009
    CA
    Thanks Terry. Sounds like I have a little work to do for the best results
  2. #122
    DIY Senior Member suceress's Avatar
    Mar 2008
    LA
    This is an update: I purchased two Toto Drakes with SanaGloss almost a year ago. Due to natural disasters, injuries, illnesses, and various other lemons life has thrown at us, we've only installed one. It is currently the only working toilet in the house with four people (one of them is large enough to be two people-- and eats enough for three people).
    The Drake is the first low-flow toilet we've owned and it took some getting used to. Certain people with digestive problems tend to spray diarrhea all over the bowl (above the waterline-- which didn't happen in the old toilets because the water level was so high). I imagine the SanaGloss would work fine if the toilet was cleaned immediately after. Unfortunately, the offenders don't clean up after themselves and I've been left to try to clean it up. I really have to scrub to get that stuff out. (Are there any special toilet brushes that are safe to use without scratching the finish?-- I think the SanaGloss finish in mine is now pretty much ruined from having to be scoured). Cling gel has made the cleaning a bit easier for me, but I don't know if it is worse on the finish-- the bowl is so stained now that I think the point is moot.
    I'd also like to note that I was ignored when I told people in my household not to use the blue stuff in the tank-- and it will stain the bowl around the waterline (I'm not sure if this is permanent because it was covered by the iron/rust stain). Also, if you have unfiltered/unsoftened water like me (and have a lot of iron in the water) it will stain the SanaGloss. The water from my faucets comes out anywhere from yellow to red to brown and tends to yellow everything (I'm working on getting a water softening and filtering system setup, but we will need to pour cement first).
    The toilet itself has only clogged about two or three times (not counting the past few weeks because the septic tank overflowed) and was easily cleared with a plunger. Even when clogged, I didn't really have an overflow problem until the septic tank got too full (we think maybe the overflow pipe from the septic tank needs to be cleared). Our old toilets were clogged once or twice every month, so this is a vast improvement.
    The only other thing I will mention is that the lid on the back doesn't have a lip to hold it in place so it tends to slide when bumped. It's not a big deal, but its something to take into consideration if you care about that sort of thing.
    Overall I'm still satisfied with the toilet. If you're not used to low flow it can make cleaning more challenging, but it flushes well.
    I hope this made sense and was at least moderately helpful to people. Mostly, don't make the mistakes my family made. Get your water filtered first and don't use the blue stuff! (And if you are a sprayer-- please show some courtesy and wipe the brown away immediately so it doesn't dry on and stick).
  3. #123
    DIY Junior Member whtdove3's Avatar
    Feb 2009
    Chicago, IL
    We had a Toto Drake 1.6 gpf, round seat, installed last week and am very pleased so far. My hubby was a bit taken back by the low water in the bowl, but came out the first day and said, "One flusher...thumbs up!"
  4. #124
    DIY Junior Member Photon1's Avatar
    Mar 2009
    Idaho
    I bet the wax ring is pushed over the hole. I just don't see how a normal persons poo could plug this toilet....even if you use 5 large wads of TP it really shouldn't plug.
    I purchased the Kohler Cimarron at Home Depot. Before the installer came I read about the Toto Drake on this board.
    I happily returned the Cimarron and purchased a Toto Drake (ADA) model.
    I had it professionally installed.
    I was underwhelmed by the flush but read that most of the action was below the water surface.
    The very first time out (under real conditions) it clogged and I had to plunge.
    I am at a total loss as I read most if not all of the very positive posts here and I don't recall a one clog or negative comment about this product.
  5. #125
    Aug 2008
    Fairfield Co.,Connecticut
    Quote Originally Posted by Robert H View Post
    Since I made my decision based in information from this site and forums I though it only proper to post. I replaced 20+ year old toilet with a basic round seat Eco Drake. I cannot believe that I can be so enamored with a toilet. This thing is great you flush, everything goes away and the bowl is clean. The first flush I though something was wrong because of the low water flow. One thing I really like is that there is none of the noise or potential parts failure of a pressure assist system. A good gravity design is the way to go!
    Robert
    Toto Drake Installation instructions
    I installed them 3 months ago and I still smile every time I flush
  6. #126
    Default toto drakes
    I've got two toto drakes and i think for 1.6 gpf toilets they are one of the best toilets out their but they are still left in the dust by my 1959 "standard". I've had one of them installed for 2.5 years it's a round bowl model it has clogged but not with waste but rather with toilet paper, that was in my bathroom upstairs for two years then before christmas i moved it to our downstairs bathroom to make room upstairs for my "standard". the downstairs bathroom is the one my mom uses and the last two toilets i tested down their got complaints of too much smearyness the drake smears much less than the other two but still can smear pretty bad. since it's been in the downstairs bathroom it hasn't clogged once except when my dad tried to flush old vegetable soup down it with whole carrots in it, then i had to get the auger out . overall i think it's one of the best performing 1.6 gpf toilets on the market and it really passes the test in our house and we've put it through hell in the past 2.5 years. the second drake i got at christmas that's an elongated model i just set it up outside today for testing it performs just as great as the first one though im not ready to install it yet.
    my moms friend has three drakes in they're three year old house they've had theirs clog too but just on toilet paper they're happy with there's and that's actually how i discovered toto's and decided i had to have one.
    i very strongly recommend them to everyone i know.
    Jonathan
  7. #127
    DIY Junior Member pauldv's Avatar
    Mar 2009
    CT
    Default Height of ADA toilet at 17"????
    I just had an ada Drake installed. Great toilet, but a little to tall (measures at 17"). I have an American Standard Champion right height that is 16 1/2" tall. Just right.
    The specs for the Drake ADA say that it is supposed to be 16 1/2" tall. I don't understand how the spec could be that far off.
    The 1/2" should not make such a difference but it seems to.
    I want to replace the American Standard with the same Drake but really want 16 1/2".
    Can someone measure the height of their drake an see if its also 17" tall. (measurement without the seat)
  8. #128
    Comments by readers Reader Review's Avatar
    Jan 2006
    Terry,
    Thanks for the help yesterday and recommending the Drake. It works great!
    J.D.
    Snohomish WA
    Your qualified model is the Toto Eco Drake CST744E
  9. #129
    DIY Junior Member hudson's Avatar
    Apr 2009
    NC
    Default Purchase Experience Toto Drake CST744SL
    After reading this forum, I decided on a Drake Elongated ADA toilet...CST744SL. I'm in NC. I went to the TotoUSA website and found the nearest supplier and called them. They said they had the CST744SL and gave me a price. I drove to the supplier and picked it up. When I got home, the tank said Eco on it....see attached picture. I called the supplier, she said that she could no longer get the 1.6 GPF Drake tank and by law she had to sell the Eco tank. She assured me that all was well and I called my plumber who installed it. The combination flushed very well. I noticed that the water didn't fill up to the place in the bowl where it looked like it should. Also the tank moved on the bowl...plumber error I believe. The bowl said 1.6 GPF; the tank said 1.28 GPF. I emailed TOTOUSA Support...they promptly replied that the combination was wrong and that I should have a ST743S tank. I called the supplier who said she would swap the Eco tank with one in the show room. She had someone check it out before I swapped the tank. When I got home to install it, it was missing hardware to connect the tank to the bowl. It was missing the hose and clip that goes from the Gmax fresh water inlet valve to the downspout. I bought 2 sets of hardware to get the identical bolt setup as in the installation instructions and a corky valve device to get the correct hose and clip. I finished the installation myself...the water in the bowl is correct...the unit flushes like none other. The tank fits tightly on the bowl. I love it...If you don't suceed at first try again! From all of the excitement above I learned that one should check and double check before you take anything off of the loading dock. If you get a Drake you should end up with 2 boxes a bowl with C744SL and a ST743S tank. Since I had half an Eco for a week, I found that the Eco really works well, and that will be my next purchase.
    Question: Should water and air bubbles come out of the base of the GMax/Korky style inlet valve...(all inside the tank)?
  10. #130
    Apr 2009
    NC
    Default As part of my research, I posted a Toilet Question
  11. #131
    Dec 2007
    Quote Originally Posted by hudson View Post
    Yes the water does come out of the bottom of the Korky and it usually will have bubbles as well.
    Sorry to hear everthing got mixed up at the supplier. Usually things work out better than that.
    I like those boxes that say made in USA...
  12. #132
    Dec 2007
    That forum got off to a rough start but it looks like the investors kicked it up a notch in the end...
    Looks like Toto Drake is a winner in the investment community...
  13. #133
    With the Drake, you can use the E bowl with either the S tank or E tank.
    I haven't seen an S bowl in some time now.
    When they pull fixtures out of a showroom, any number of things could be robbed. Sometimes, knowing they will never see water, they barely assemble them.
  14. #134
    Apr 2009
    NC
    Default One last Question
    Thanks for the helpful replies!
    When you flush the Toto Drake...and do not hold down the lever, only about half of the water goes out of the tank.
    I think that's by design, but I'm not sure.
  15. #135
    Dec 2007
    Yes that is by design.
