Results 1 to 3 of 3
Thread: Water Softener Issues
    DIY Junior Member dunkinidaho's Avatar
    Aug 2009
    Michigan, USA
    Default Water Softener Issues
    Today I have a question regarding my water softener. I'm not sure I have it set correctly. It is a 40,000 gr. single stage design with 4 stages of cycling. The issue I have surrounds the time I have each stage set for. I have tried for a few years to find information on this on the net without success. It seems the industry has a muffle on the subject. There are only two people in my home and we don't drink the water as we have an RO system. We are on a well. We use K-Lite not salt. I have 1000gals set between cycles. The unit is a Fleck 5600se single backwash. Other settings are:
    Iron 340000 units
    Backwash 16mins.
    Brine Rinse 16mins
    Rapid Rinse 18mins
    Brine Refill 11mins
    Any assistance with this would be helpful
    Nov 2010
    Maine
    Without knowing how much hardness and or iron you are trying to remove I can't tell you whether or not its set right
    Aug 2009
    Michigan, USA
    Thanks for the response, I'll read you the analysis off the paper:
    results units DL method reference
    hardness by calculation 340000 ug/L 5000 EPA 200.8 rev 5.4
    Manganese not detected
    Does this help
    Brian
  1. How to empty water softener? (Kenmore deluxe demand water softener 625)
    By birkoff in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-22-2013, 08:56 PM
  2. water line issues between shower and hot water tank drain P-trap
    By ns in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2011, 10:55 AM
  3. Hot Water Issues
    By rew70 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-13-2009, 11:07 AM
  4. Iron Bipfouling/softener issues?
    By Ms Thistle in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-29-2009, 08:01 AM
  5. Hot water issues
    By lefty in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-13-2007, 06:39 PM
