Thread: 15' branch to lav sink, 2 toilets: 1/2" sufficient?
    DIY Senior Member speede541's Avatar
    May 2010
    San Francisco Bay area
    Default 15' branch to lav sink, 2 toilets: 1/2" sufficient?
    I'm wondering if the water flow at a lavatory sink will be impacted if it shares a 1/2" copper branch also connected to two pressure-assisted low flow Gerber dual-flush toilets?
    I can pretty well guarantee at least one of those toilets will often be refilling when the faucet is used, and probably at times both.
    The branch will be about 15 feet long in total, with the sink being the first fixture at about 10' on the branch (not sure if that even makes a difference).
    May 2010
    One of the toilets is currently installed elsewhere, fed by a 1/2" branch off a 1" main, where it takes 50 seconds to recharge. So a real life 2.0 GPM, vs. a "book value" of 3.5 I think I'm supposed to use according to a pressure drop table I looked up.
    Also, the bathrooms being serviced are on a 3rd floor of a house that's already off the street, so I'm assuming a 13 PSI pressure drop for 30 feet of lift. But we have excellent water pressure here -- I believe near 80 PSI at the service entrance.
    So I'm not sure if I should be using 1.5 + 2.0 + 2.0 = 5.5 GPM for sink + 2 toilets which I think is real (and about 7.5 ft/sec flow rate), or 2.0 + 3.5 + 3.5 = 9 GPM which I think is the "book" value, because apparently that bumps me into the "undersized" region of the chart with a 12 ft/sec flow rate.
    Two low flow toilets and a lav are fine on a 1/2" line.
    http://www.terrylove.com/forums/show...18-a-big-Flop!
    May 2010
    Thanks for the confirmation.
    Re: your link, yeah, I bought the DF's based on CR's review, back well before I discovered your site, and around the time you wrote that post. We bought three. One is still in the box, but the other two have been performing flawlessly. However I did go with a Toto for a fourth recently partly due to your recommendation, partly because the Gerber's being slightly noisy for a guest bath near the kitchen, but mostly because of dimensions.
  1. Question about connecting 2" wet vent to the 3" branch that it will serve
    By James Andereggen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-23-2012, 12:40 PM
  2. if i install 1/2" water pipe, as a branch----
    By bsa_bob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-18-2011, 09:35 AM
  3. Replies: 15
    Last Post: 03-06-2011, 05:43 PM
  4. 25"x22" Stainless drop-in sink in 27" sink base cabinet?
    By John414 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2010, 08:12 AM
  5. Thoughts about Niagara Conservations toilets and 10" Rough In Toilets
    By wanderin in forum Toilet Forum discussions
    Last Post: 06-02-2008, 05:35 PM
