Results 1 to 4 of 4
Thread: well water pressure/volume question
Hybrid View
    DIY Junior Member
    Jun 2013
    North Carolina
    Default well water pressure/volume question
    I am trying to figure out what causes our water to lose pressure. Just using it for the house ie showers washing etc it seems fine but when watering with a hose for a length of time the pressure drops quite a bit. It makes our sprinkler system useless. The work fine for a few minutes then the pressure drops and they wont work.
    How can i diagnose this problem. Is our pump to small or does our well water level drop? Or is it some other issues. We dont ever seem to run out of water though.
    Jan 2008
    As you pump, you are lowering the water level in the well. A good pump man can test the recovery rate of the well to determine if a "bigger" pump can be installed without over-pumping the well.
    DIY Senior Member thassler's Avatar
    Dec 2006
    Tennessee
    Could be you've pumped the water down to the pump intake level and the pump is only giving you what the recovery rate of the well is.
    TreyH
    ** Not a professional - only a DIYr **
    Feb 2011
    NW Ontario, Canada
    Pump GPM runs on a curve based on how high it needs to lift the water. When drawing faster than the pump can produce, the pressure drops.
  1. water volume question
    By monkeybrains in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2010, 07:47 PM
  2. Question on installation methods regarding pressure and volume/
    By joebartolucci in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-14-2009, 04:05 PM
  3. Pressure OK, but water volume low
    By Plumbob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-04-2008, 08:43 PM
  4. Pump volume and pressure question
    By djdixon1995 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-18-2008, 06:00 AM
  5. Very low domestic water volume & pressure ?
    By kipph in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2005, 06:00 PM
