Thread: Floor drain in my mechanical room
    Certified Idiot murley's Avatar
    Jun 2013
    QC Illinois
    Default Floor drain in my mechanical room
    I will be installing a tankless water heater that will NOT be located in my mechanical room. There will, however, be a furnace, clothes washer, and sink.
    Do I still need a floor drain for the mechanical room? (condensation drain from furnace or in case of washer failure)
    Thanks again!
    DIY Senior Member speede541's Avatar
    May 2010
    San Francisco Bay area
    I'm glad you're thinking about it.
    My architect left me with a basement mechanical room with no floor drain, no provision for a condensate drain (have to run a wall-mounted pipe around half the room to tie in elsewhere), an no connecting walls for my boiler and clothes dryer breather/exhaust ducts (bends everywhere). I didn't know any better, and my general didn't catch it, either.
    Many of the newer furnaces need a condensate drain, as do many tankless water heaters. You may be able to drain those either at the sink or the washer. In fact it's mentioned in the tankless instructions that the washer is a preferred place to drain because it counters the acidic water coming from the tankless.
  1. Mechanical room layout- radiant with solar tie in
    By minniehill in forum HVAC Heating & Cooling
    Last Post: 02-20-2012, 10:29 AM
  2. How to prep a laundry room floor with floor drain for tiling?
    By benze in forum Remodel Forum & Blog
    Last Post: 08-30-2010, 12:18 PM
  3. Floor drain in laundry room
    By red22769 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-17-2010, 06:04 PM
  4. Floor drain in laundry room
    By kd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2006, 08:12 PM
  5. adding floor drain for second floor laundry room
    By illinipdx in forum Remodel Forum & Blog
    Last Post: 01-12-2005, 08:51 PM
