Results 16 to 30 of 39
Thread: To Clean or Not to Clean sand out of well
  1. #16
    DIY Senior Member tvl's Avatar
    Jul 2006
    South Carolina
    Quote Originally Posted by VAWellDriller View Post
    If this is a mud rotary drilled, screened well in a sand formation (which I think it is).
    You are correct ............. sand well for sure!
    Again, my thinking was that a 6 inch pipe/screen would have more "slots" around the circumference of the pipe versus a 4 inch pipe, thereby allowing more water to flow into the casing ........ which would provide more water to the pump? So, that is not a correct assumption? Shucks!
    Well, are there any other reasons I might want to consider a 6 inch well before I make my final decision?
    Thanks so much!
  2. #17
    Moderator valveman's Avatar
    Mar 2006
    If the gravel pack is done correctly, you won't see much difference between 4" and 6" casing. However, if you ever have any problems down the road, you will have more options with the 6" casing.
  3. #18
    Jul 2006
    South Carolina
    OK ......... I would love to know what those options might be. Would you please let me know. Thanks again!
  4. #19
    Mar 2006
    You not as likely to get the pump stuck. If the pump gets hot and melts the casing, the 4” will grab the pump and you can’t get it out, and you will need to dig a new well. You have room to install a 4” liner should the 6” casing develop a hole or crack. We can get more equipment down the 6” hole like bailers, surge blocks, fishing tools, etc. And with 6” casing I can put a 4” shroud on the pump, which I think is very important for the longevity of the pump/motor.
  5. #20
    Jul 2006
    South Carolina
    Thanks a lot Valveman!
    You mentioned: with 6” casing I can put a 4” shroud on the pump, which I think is very important for the longevity of the pump/motor. So, if I do go with the 6 inch well, it appears I need a shroud for my pump. The well digger did not mention anything about this. Where do you get this item? And how is it installed?
  6. #21
    Mar 2006
    Quote Originally Posted by tvl View Post
    I just make them from a short piece of 4", 100#, sewer pipe. Cut three pie shape wedges out of the top. Use a 4.5" hose clamp around the wedges that are left to tighten it to the pump. Then tape over any cracks with good electrical tape. Here is a video of installing a shroud, it is just on a larger pump.
    http://www.youtube.com/watch?v=sVBpCVqX7Jk
  7. #22
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    I hate the term "well digger"
  8. #23
    Mar 2006
    Quote Originally Posted by craigpump View Post
    It is a lot better than some of the things I have been called.
  9. #24
    Jul 2006
    South Carolina
    I certainly don't want to offend anyone .................. what is the proper term for an individual who installs and maintains water wells???
    Mar 2006
    "Crazy", “Gluten for punishment”, “Always late for supper”
  11. #26
    Apr 2012
    ct
    ....divorced.
  12. #27
    Mar 2006
    ....divorced.
    “Divorced” Lol. “Hypertensive”, “Irritable”, “Stubborn”, “Cranky”
  13. #28
    DIY Senior Member VAWellDriller's Avatar
    Sep 2012
    Richmond, VA
    As a driller and pump installer, I agree with all the benefits of a 6" well that valveman mentioned, however in your case if it's twice as much, I don't see the real advantage to you. You can't shrourd a 4" pump in a 4" well, and you can in a 6, but you only really need a shroud if when you have a top feeding well. You won't have a top feeding well, assuming you don't hire an idiot who puts the pump in the screen. On residential, we always install 4.5" casing, which gives you a nice little extra wiggle room for the pump. As far as your thoughts on water volume, that is more function of the type of formation, not the screen diameter.
  14. #29
    Mar 2006
    VA is closer to your area. Sounds like good advice to me.
  15. #30
    Jul 2006
    South Carolina
    After much consideration, I have decided on the 4 inch well for our irrigation system. The 6 inch well is just too much money and doesn't appear it can be justified.
    As VA stated, this will be a bottom feeding well and is what my driller has also stated. He is going to do one additional item in an effort to get the most GPM he can. He anticipates going through one if not two SMALL "acquifers" before he gets back into the main acquifer that most folks around here are now using. When he goes to set his casing, he will add screen to the sections where he has found water ......... no matter how small the stream. This will allow additional water into the casing. Naturally, he will have to gravel pack more this way, but he seems to feel this will be good for me in the end.
    Thanks for everyone's help!
  1. Blocked off clean out?
    By markbair in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2012, 08:24 PM
  2. Water Well Clean Out?
    By Michael Holmes in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-20-2011, 05:05 PM
  3. clean windows
    By ActionDave in forum Remodel Forum & Blog
    Last Post: 04-21-2009, 07:04 AM
  4. sand filling up well, how to clean??
    By hadalgo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-18-2008, 11:50 AM
  5. Indoor clean out
    By mattt19 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-13-2008, 05:23 PM
