Results 1 to 4 of 4
Thread: Existing Pex Restrictions
    DIY Junior Member marybythesea's Avatar
    Jun 2013
    Kingston, WA
    Question Existing Pex Restrictions
    Hi, This is my first attempt to blog ...if I make mistakes, please advise. I need help. I ran 60' of 3/4" poly underground from a newly installed outdoor hydrant to the vicinity of an existing outdoor hydrant (in order to tap into its water supply). I uncovered the existing outdoor hydrant and found a T connection, one leg bringing in the main water supply, one leg to the hydrant, and the third leg was a 2' long section which had been capped for future use. It was all buried blue 3/4 pex which I can barely read but seems to say PEXa REM?? UV shield 120. I did not know how to connect to PEX so I called a plumber. He said he could not connect the capped PEX line to the poly because the existing PEX was "rayhow" and took a special tool. I asked if he meant the connector or the tubing ...he said the connector ...I asked why he couldn't just cut off the cap and use a different type of connector ...he said "well this type of blue PEX can only take a special connector which takes a tool costing thousands of dollars" I asked the name of the special connector and the special tool, but he could "not remember" the name. I felt uneasy as if he did not want the (small) job and was making excuses. From my online search, I found an expansion tool that costs between $199-399 by I saw no evidence that it alone was good for a particular pex tubing. Is it true that some types of PEX only take one kind of fitting, the tool for which costs thousands. If so, how would I identify that kind of PEX from other type a PEX. I would do the job myself if I knew what tools to use. Thanks in advance for guidance. marybythesea
    Mary,
    The Poly can use an insert adapter to threaded, and the PEX can be threaded by sharkbite.
    I prefer not to use a sharkbite fitting, but they do work and they are a listed fitting. And yes, it's a doable thing for a homeowner.
    Default Pex
    That type of connection, "Wirsbo", only works with that type of PEX, but the "conventional" PEX fittings and connectors work with ALL types of PEX, including yours.
    If the outdoor hydrant is only two feet away, you could also dig it out and connect to the threaded fitting there.
  1. Existing 1/2"
    By exeunt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-23-2010, 06:42 AM
  2. Restrictions in Pex Modular Home
    By Bill3888 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-18-2009, 06:37 PM
  3. low flow toilet with size restrictions
    By knabe in forum Toilet Forum discussions
    Last Post: 02-01-2008, 11:50 AM
  4. Flow rate? Flow thru? Water softner restrictions.
    By polocash in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2005, 10:16 PM
  5. Shower 2.5 Gal Restrictions
    By Latch in forum Shower & bathtub Forum & Blog
    Last Post: 12-13-2004, 08:38 PM
