Results 1 to 1 of 1
Thread: Do Tankless Heaters require pans and pop off valves?
    DIY Member jed1154's Avatar
    Feb 2008
    Texas
    Default Do Tankless Heaters require pans and pop off valves?
    Trying to get some plumbing done and need to add an ELECTRIC tankless heater upstairs. Im told I need a pan and a pressure releif valve. The pan has to go to a drain line somewhere and the blow off valve has to go to the outside of the home. Is this true? I have 3 other ELECTRIC tankless heaters in my home...NONE of which have pressure relief valves or drip pans. So, Im trying to see if its require by code now in Texas or something.
  1. Does 10% resin require impact softening capacity and does it require a special screen
    By estein9 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-03-2013, 11:31 AM
  2. Tankless Water Heaters
    By foxhome01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2008, 01:29 PM
  3. Tankless Water heaters
    By Master Plumber 101 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-17-2008, 08:29 PM
  4. Does a dual water heater installation require that the water heaters be the same size
    By GooSkinBaldi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-29-2007, 02:28 PM
  5. Tankless water heaters
    By srdenny in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-18-2007, 01:21 PM
