Results 1 to 5 of 5
Thread: Flek 7000sxt constant drain
    DIY Junior Member Cobra1365's Avatar
    Feb 2011
    Delaware
    Default Flek 7000sxt constant drain
    just installed a new neutralizer tank with Fleck 7000sxt. As soon as I came out of bypass, the system started draining. Tried depowering but it goes to drain each time I come out of bypass.
    Feb 2011
    Delaware
    Disassembled verything and started from the beginning again. Did not see any foreign matter or anything that I missed. Forced a maual regen and everything seems to be working now. Just one of those queertrons I guess.
    I'll keep an eye on it over the next couple of days to make sure everything is working as advertised.
    Jan 2012
    California
    Check out the video in my signature. It will show you the syncronizing of the valve. Be sure the "S" is lined up with the arrow.
    Hope this helps.
    FYI, the filter valve and softener valve syncronize in different positions, but the letter "s" is the service position.
    Feb 2011
    Delaware
    Question...what does the turbine do? There is not one in my unit (neutralizer, not a softener).
    Jan 2012
    California
    The turbine is the meter. Filters typically backwash on a time basis, not a volume basis.
  1. Drain line on a Fleck 7000SXT w/ 5gpm DLFC...
    By jkats in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-04-2013, 08:11 PM
  2. Clack Drain line constant drip
    By cwmn in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-12-2012, 11:20 AM
  3. Constant drip down drain valve from Culligan Iron-Cleer
    By Pkenn in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-31-2011, 01:25 PM
  4. VFD's, CSV's, Constant Pressure Pumps, Constant Pressure Valves
    By Terry in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-05-2009, 02:58 PM
  5. constant flow control rather than constant pressure
    By mbartosik in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-28-2007, 08:44 AM
