Results 1 to 10 of 10
Thread: Garbage disposal install
    DIY Member mar3232's Avatar
    Oct 2011
    Indiana
    Default Garbage disposal install
    Let me guess, you should probably put thread lock on those 3 bolts that tighten the mounting clamp on a disposal. ? I'm not a plumber and installed the disposal about 2 months ago -- thought it sounded noisy and looked down there to see that a couple of these bolts had backed out.
    Of course no where in the instructions did it mention putting a thread lock compound on them.
    More likely the putty squished out and the flange was loose because of that.
    I try to use very little for that reason.
    Oct 2011
    Indiana
    Terry, thanks -- I should probably remount it then. I have a feeling I used way too much putty. I think because I don't use it all the time, I think the more the merrier because I honestly can't believe it works compared to something like silicone etc. (which I know you shouldn't use).
    It's not leaking though -- if you think I just tightened it up and did the thread lock I'd be ok? thnaks
    If you snugged it up it should be fine. That will squeeze the extra putty out.
    Default disposer
    We can't tell why it came loose, but I have never used "LockTite" on the bolts, nor have I ever seen it done. Install the disposer correctly and it will not come loose.
    Oct 2011
    Indiana
    I know Terry hit it on the head -- too much putty -- hence, probably making it slide around too much. It was done right, but just that -- too much goo.
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    Not to nit pick, but perhaps not done right if too much putty (or maybe more to the point, didn't snug up the 3 bolts adequately at the time of install since that would have forced out the excess putty anyway).
    Not a pro, but have have never used thread lock and have never seen the bolts come loose despite all the vibration a disposer creates.
    When there is too much putty, it can show up later, just the way it was mentioned above. We've all done it at least once.
    Feb 2005
    Omaha, NE
    Good to know, Terry. I didn't realize that was possible. I have always erred on the side of using a pretty thick rope of putty, figuring out the excess would get squeezed out (and recycled back into the container).
    Still seems to me that if the flange is angled at all, it wouldn't be possible for excess putty to hang out under the flange?
    Plumber MichaelBukay's Avatar
    Jan 2013
    San Diego, California
    I have installed hundreds of disposals. I only had one install where the collar came loose. I agree, probably too much putty. I think thread lock is a bad idea overall for that application.
  1. Garbage disposal install in double sink w/dishwasher... why do I have two drain pipes
    By s_mack in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2011, 01:38 PM
  2. install garbage disposal in double sink
    By homey6660 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2009, 07:35 AM
  3. Electrical Options For Garbage Disposal Install
    By Verdeboy in forum Electrical Forum discussion & Blog
    Last Post: 11-13-2007, 10:21 AM
  4. Garbage disposal
    By Cookie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-19-2006, 08:16 PM
  5. Garbage disposal
    By armallard in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-26-2006, 03:52 PM
