Thread: install schluter flange to trap
    DIY Member jerome7's Avatar
    Nov 2010
    Default install schluter flange to trap
    Hi all
    I want to install a Schulter flange for my shower and the instructions says I need to press it down on the mud bed.
    However my ABS drain pipe is flexible and goes down upon applying pressure. How do I ensure the flange is well connected to the pipe?
    Note my subfloor is still not in place, thus I still have access to the drain pipe.
    You can use a cat claw to reach down and "grab" the ABS pipe and prevent it from pushing down.
    If you can figure out what height the trap should be at to allow you to bed the drain properly, you could add some blocking to prevent it from moving, or strap it.
    Nov 2010
    After I replaced the trap, I was able to put some blocks under it.
    Just curious, if I were to use a cat claw, do I grab by putting it inside the pipe?
    Outside will be hard given schluter has such a big flange.
  1. Schluter trim and my install
    By boardable in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2012, 06:28 PM
  2. Schluter's Line Drain - A closer look at the new linear shower drain from Schluter
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 07-15-2011, 07:47 AM
  3. Shower trap install?
    By Rod M1 in forum Shower & bathtub Forum & Blog
    Last Post: 03-29-2009, 08:01 PM
  4. Schluter-Kerdi shower install needed
    By cclearly in forum Shower & bathtub Forum & Blog
    Last Post: 10-31-2008, 01:06 PM
  5. P-trap install
    By lhoward145 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-18-2008, 03:37 AM
