Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Question about temporary pressure tank and yard hydrants
    DIY Junior Member driftless's Avatar
    Jun 2013
    Wisconsin
    Question Question about temporary pressure tank and yard hydrants
    Hi guys, thanks for the great forum here. Helped me install a Grundfos at 300' without a hitch.
    So here's the situation: My wife and I bought 40 vacant acres in SW Wisconsin and are living out of a yurt for a couple of years until we can build a house. Last summer we drilled our well (300', water at ~150'), installed the Grundfos SQ-Flex (we are on an off-grid solar system) and ran 1" poly in a 7' deep trench from the pitless to two yard hydrants. The pump is wired directly to a circuit breaker, so we open a hydrant THEN turn on the breaker, fill up containers with water /water the garden, turn off the breaker THEN close the hydrant. I know, I know, I know, we're playing with fire.
    We figured we could save some money and live with this for the year or two before we built the house and put in a proper pressure tank system in the basement. Well, as we're getting more animals on the farm and planning our wedding for the fall (on our land) we're thinking it would be really nice to have on demand water, even if only in the summertime. Which brings us to my crazy(?) idea:
    Can I run a line from one of the yard hydrants to a pressure tank / switch and still use both hydrants? The first yard hydrant would always be open with a T at it's outlet, one side going to the pressure tank, the other side to a garden hose. That seems like it would work fine to me, but what happens with the other hydrant? When I open hydrant #2, water would flow from the pressure tank back through hydrant #1 to get to hydrant #2. How terrible for the system is that?
    This would just be for this summer and next, and then I can move the setup to the basement when I build the house. Can something like this be done, or do I need to dig back down to the buried pipe and just put everything before the hydrants? I'd like to avoid that because my soil is clay and huge rocks (I busted 3 teeth off the bucket of the digger I rented to dig the trench the first time....). And that digger is expensive....
    Thanks for looking.
    Feb 2011
    NW Ontario, Canada
    Maybe draw a picture as my mind's eye cannot. The pressure tank, if it is the captive air bladder type, does not know (nor care) where the water goes once it leaves it. A bladder tank has no separate in versus out port.
    Jun 2013
    Wisconsin
    This picture MIGHT help....
    I am thinking of a bladder tank, and I feel like it will work. But what I don't know about plumbing would fill a book, so I'm hoping to bounce it off this knowledgeable community.
    Feb 2011
    NW Ontario, Canada
    Just so long as it doesn't have to go through much of a valve constriction of the hydrant, it would be fine. Instead of Y'ing it after the hydrant, you should Tee before.
    Jun 2013
    Wisconsin
    Yeah, I know it would be best to tee before the hydrants, but that would mean renting that digger again and digging back down the seven feet. And I'm thinking a T after the hydrant, I guess the drawing is misleading. A Y would be really hard on the 'backflow' from the tank to the garden hose, right?. Thanks for the input!!
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Why don't you try an in well tank? I have never used one, but I know some people who have and have had good luck with them.
    Jun 2013
    Wisconsin
    Interesting! I've never even heard of this.... Just did a quick google and looked at In-Well Technologies products. Does anyone have any direct experience with these? The drawdown is only around a gallon, that's a drawback.
    Feb 2011
    NW Ontario, Canada
    A lot of jurisdictions now require a spigot at the wellhead. I wonder if they use a different pitless that lets one Tee off the top of it or how they do it.
    Do you use a frost-free hydrant where the actual valve is below ground making it hard to Tee off? I don't understand why you bury the pipe so deep for Nevada? It's not like you have frost that deep.
    Jun 2013
    Wisconsin
    I'm on the road working right now, my land and the plumbing are in Wisconsin. So yes, it's a frost-free hydrant, buried 7 feet deep.
    Apr 2012
    ct
    Jurisdictions that require a spigot on the well? Hmmm never heard of that, I wonder if that's unique to Canada?
    Feb 2011
    NW Ontario, Canada
    I don't recall where I read it but it wouldn't be Canada cuz it would freeze in these parts.
    Apr 2012
    ct
    Freeze in Wisconsin too...
    Martinson makes a pitless that is designed to have a pressure relief valve installed on it, someone could take one of those and fashion a stand pipe up through a well seal and attach a spigot to it.
    DIY Senior Member VAWellDriller's Avatar
    Sep 2012
    Richmond, VA
    What you want to do will work just fine as a temporary system....the only problem will be if anyone shuts the yard hydrant that the pressure tank and switch are attached to....
    Sep 2012
    Richmond, VA
    forgot to add, I tried to buy an in-well tank a couple years ago for a simial project, and every salesman I talked to at my normal distributors said they never worked or lasted long. No personal experience...that's just what I was told.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by craigpump View Post
    The OP had Nevada as his location before he changed it.
    Got a link to that Martinson?
  1. Shallow well - temporary loss of prime / pressure - no air in line
    By unique in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-04-2011, 07:53 PM
  2. Well-trol pressure tank wx 202 operating pressure question
    By tlpayne in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-04-2010, 03:02 AM
  3. Temporary Water Pressure Loss
    Last Post: 08-23-2008, 06:19 AM
  4. yard hydrants
    By dickie5 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-08-2006, 07:17 AM
  5. No Pressure For Yard Hydrant Unless Pump Is On
    By AlanB in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2006, 01:13 PM
