Results 1 to 2 of 2
Thread: pre charges
    DIY Junior Member brenjake's Avatar
    Nov 2011
    cincinnati oh
    Default pre charges
    Hello I am new at this...but here goes I just installed a grundfos mq-45 booster pump. It is 1hp. It has a precharge tank built in of 25lbs. I have a 86 gal bladder type tank precharged at 38lbs from factory.I am drawing fro a adjacent cistern. My question is since the pump is factory set to start pumping at28-30 lbs. should I lower the bladder pressure tank to 2lbs below the cut in at 28lbs as instructed by the tank manufacturer? EG lower the precharge to 26 on the pressure tank? thanks for any help.
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    Quote Originally Posted by brenjake View Post
    Yes, but with that baseball size tank it is not going to help much. When you decide you want a reliable pump, get a standard jet pump with a regular pressure switch and either a large pressure tank or a CSV and small tank.
  1. bad ground & electricity charges?
    By darque in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-21-2010, 04:00 PM
  2. Outrageous furnace repair charges
    By bobbobwhite in forum HVAC Heating & Cooling
    Last Post: 03-02-2010, 11:57 AM
  3. Repair charges?
    By steve317 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-10-2008, 06:27 AM
  4. plumbing charges
    By markmark in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2007, 06:07 AM
