Results 1 to 5 of 5
Thread: Extension for tub drain linkage assembly?
    DIY Junior Member 44windgate's Avatar
    Jun 2013
    Baltimore, MD
    Default Extension for tub drain linkage assembly?
    I am in the home stretch of a bathroom model. A plumber roughed-in the supply/drain lines and set the tub. I had a slightly larger/taller than standard tub. He did a good job, but when he left he showed me how the waste and overflow drain that I had purchased worked, but the stopper did not go deep enough to block the drain. It is all the way extended on the threaded portion.
    Has anyone heard of an extension for a PVC drain linkage assembly? If all else fails I will probably remove the trip lever drain setup and change out the drain/strainer to a twist-type.
    What brand of overflow?
    Jun 2013
    Baltimore, MD
    Terry, Thanks for the reply, it is a Watts Overflow (see below). I emailed Watts, but they recommended installing a different overflow. If there is an easier solution (extending the linkage) I would like to try that first.
    Watts - Trip Lever Bath Drain - 4BN - 1 ” white plastic tubing
    Plastic construction
    Trip lever-style trim
    MFG Brand Name : Watts
    MFG Model # : 4BN
    MFG Part # : 0145788
    100677386
    I'm with them.
    I would pick up one that fit.
    If this over a crawl space, or someplace you have access to?
    Normally if it's concealed, they like a solvent weld (glued) joint W&O
    They also make drains with cables.
    Default drain
    I just use a piece of brass rod, often a toilet tank ball lift wire, and fabricate an extension.
  1. Toilet drain extension for remodel
    By AlterB in forum Toilet Forum discussions
    Last Post: 03-31-2013, 07:22 PM
  2. tub drain linkage assembly not stopping water
    By karkalec in forum Shower & bathtub Forum & Blog
    Last Post: 04-27-2011, 05:53 AM
  3. New Tub & Drain Assembly
    By billrea99 in forum Shower & bathtub Forum & Blog
    Last Post: 03-28-2010, 11:02 AM
  4. Shower Drain Pipe too Short for Drain Assembly
    By ilovedogs in forum Shower & bathtub Forum & Blog
    Last Post: 07-18-2009, 08:19 AM
  5. Old Crane Stopper Linkage -- Down the Drain?
    By allthumbs in forum Shower & bathtub Forum & Blog
    Last Post: 05-27-2006, 01:57 PM
