Results 1 to 5 of 5
Thread: Would I save Oil
    DIY Junior Member Hilmar's Avatar
    Jun 2013
    New York State
    Default Would I save Oil
    Hello to All.
    I have an oil burner hat water baseboard heating system witch also makes my domestic hat water.
    All is OK in the wintertime, but in the summer the burner runs just as in the winter to make the domestic hat water.
    I use from February to September 500 Gal. Oil and from September to February 500 Gal. Oil. Would I save some Oil if I installed an extra Storage tank for the hat water? At this time the burner has only the build in coil to heat the water.
    Or is this a myth as fare as savings go? Electric is out so is local gas. 30 Gal. propane only for cooking.
    Thank you Hilmar
    Mar 2011
    Houston, TX
    Not sure that adding another tank would save you anything.
    Electricity is the most efficient for a homeowner when it comes to making heat.
    The cost may be another story. Solar is another option.
    I would use Electric, If Natural gas is not available.
    Propane is good for cooking, but a PITA to transport, Electric works good and can make Hot water also.
    Have Fun.
    In the trades Dana's Avatar
    Jan 2009
    If you set up the boiler to cold-start, and use an "indirect" hot water heater operated as a separate zone for the boiler, you'll usually get better net efficiency, and higher summertime water heating efficiency than with an interal coil. This is not the simplest thing to measure, but this has been looked at fairly carefully by the folks at the Brookhaven Nat'l Labs.
    If you then run the boiler & indirect with a heat-purging boiler control like the Intellicon 3250HW+ or similar your standby losses plummet, and your water heating efficiency rises- approaching that of system #3 (see table 2 in that linked document.)
    The problem with embedded coils is that you have to maintain the boiler at a higher temperature at idle in order to get reasonable hot water heating performance out of it- typically north of 150F, often north of 160F at the low-limit. You can experiment with just how low you can take the low-limit before you're not getting enough hot water, but don't take it lower than 140F, which can result in corrosive condensation on the heat exchangers in the boiler and in the flue if you run it much lower temp than 140F on a regular basis. (Got a make and model # on that boiler?)
    But whether installing an indirect hot water heater and smarter controls for the boiler is the best investment remains to be seen. If your house has a reasonably open floor plan you might get better overall return heating most or all of your house with ductless mini-split heat pumps, at least during the shoulder seasons, and save a lot more oil than an indirect would. Of that 1000 gallons/year only about 150-200 gallons is likely to be for hot water heating- the rest is space heating, and even a 1-ton mini-split can probably handle more than half the space heating load, at an operating cost about half that of heating with oil at recent prices. For many homes a mini-split or two can be the solution to the $4/gallon heating oil. See this recently published policy piece on relative costs and environmental impacts of different alternatives to heating with oil. High-efficiency heat pumps are right in there with condensing gas on operating cost, cheaper than pellet boilers, etc.- see figure 2 on page 6.
    Like wood stoves and pellet stoves, it's point-source heating, so doored-off rooms on the other end of the house will run colder, but far more convenient to use, and they also run as high-efficiency air-conditioning in the summer.
    Nov 2010
    Maine
    Quote Originally Posted by Hilmar View Post
    Hello to All.
    Thank you Hilmar
    Add a Super-Stor or similar indirect water heater. Add outdoor re-set controls. Have the burner tuned up and set up professionally by someone with modern combustion testing. Insulate the pipes. Save bocu bucks?
    DIY Member
    May 2012
    Brooklyn, New York, United States
    Indirect fired water heater will resolve your issue with high bills for domestic hot water.
  1. Should I trash or save this assembly?
    By cmw in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-05-2010, 07:30 AM
  2. Save my new shower!
    By ShannonT in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2009, 06:50 AM
  3. save a plumbers job
    By jcmorgan in forum Drain Cleaning
    Last Post: 02-09-2007, 01:55 PM
  4. save a plumbers job
    By jcmorgan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
