Results 1 to 2 of 2
Thread: How can i tell supply from return?
    DIY Junior Member marklamberti's Avatar
    May 2013
    staten island
    Default How can i tell supply from return?
    I am replacing a small radiator in my kitchen with a kickspace heater.
    I have a 4 zone boiler with individual pex runs to each raidator, what i cant figure out is if there is a way to tell which pex line is the supply/return.
    Is the bleeder on the radiator always on one side? is there a simple way to figure this out?
    Aug 2009
    South*East
    If you can't trace the lines out turn the heat on from a cold start. Holding both lines the one that gets hot first is the feed. Can't see what difference it would make on a toe kick heater.
    John
  1. Return Air
    By idoc4u in forum HVAC Heating & Cooling
    Last Post: 07-11-2010, 07:07 AM
  2. changing supply and return lines
    By williambonetto in forum Boiler Forum
    Last Post: 07-04-2010, 08:18 PM
  3. supply temp ver: return temp
    By rrekih in forum HVAC Heating & Cooling
    Last Post: 04-12-2010, 03:56 PM
  4. multi zone supply & return spacing 8"... 4" ??
    By hottubbrad in forum HVAC Heating & Cooling
    Last Post: 12-24-2008, 10:41 AM
  5. AC Return
    By gmrules in forum HVAC Heating & Cooling
    Last Post: 06-13-2008, 10:19 PM
