Results 1 to 5 of 5
Thread: Code relating to shower valves . . .
    DIY Junior Member ktemkin's Avatar
    Jun 2013
    Illinois
    Default Code relating to shower valves . . .
    I am a homeowner in Illinois renovating in a old house (1930s). The renovation is extensive-enough that it requires current code compliance.
    We are trying to maintain the historical authenticity of the house (because it was designed by a noted architect) and we are being told that, because of plumbing code, we are REQUIRED to install those ubiquitous, modern, single-handle shower mixers instead of the traditional, separate hot and cold valves.
    The regional Kohler showroom (owned and run by Kohler) said they are prohibited from selling individual hot and cold shower valves in the State of Illinois because of code issues.
    I am amazed by this.
    I see that there are independent temperature compensating valves (tempering valves) available, and independent pressure compensating valves (balancing valves) available.
    Can not an arrangement of these valves (located in an adjacent closet wall with a maintenance access panel) substitute for the safety functions of a single-handle shower mixers? After all, what is a single-handled shower mixer but a unified combination of these valves.
    I am willing to spend the extra money to engineer an appropriate substitute for the single-handle mixer, but I am being told that nothing will be acceptable.
    Is it true that there is no reasonable solution to this code issue?
    Some places allow the balancing valves with a two handle. I would be asking your plumbing inspector first. He's the one you need to convince.
    There are some really great looking single handle valves now, and I'm sure your deigner, were he living today would be all over them.
    Default valve
    Grohe, and Kohler used to but I cannot find it right now, makes a pressure balancing unit which installs in the hot and cold lines to a 2 valve tub/shower valve, which makes the valve code compliant.
    DIY Junior Member plmbrbob's Avatar
    Feb 2014
    Wauconda, Il.
    any ASSE1016 tempering valve ahead of the two handle in an accessible location to limit shower water to 115 degrees. not required for tub only
    Jul 2009
    North Vancouver, BC
    Keep looking
    So many single handle fixtures that work as temperature balancing, pressure balancing and also give the option of multiple shower heads.
    Lots to choose from. Dig deeper
  1. Michigan plumbing code - check valves
    By Dead Ringer in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-20-2012, 07:39 AM
  2. Detail question relating to sewage pit check valve and shut off valve.
    By Longwood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2007, 05:17 PM
  3. Code Question - Shut off valves inside wall OK or not?
    By Silversurfer7 in forum Shower & bathtub Forum & Blog
    Last Post: 02-21-2006, 12:49 PM
  4. Code Question - Shut off valves inside wall OK or not?
    By Silversurfer7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2006, 10:55 AM
  5. Replies: 1
    Last Post: 09-28-2005, 08:07 PM
