Thread: should I change the p-trap?
    DIY Member jerome7's Avatar
    Nov 2010
    Default should I change the p-trap?
    I am remodeling my shower stall. I took things down to studs and plywood.
    Is there any need to cut out the subfloor and to put in a new p-trap?
    The shower is 14 years old. How likely it is partially clogged?
    What material is the P-trap made of? If it's pvc or abs, it should be fine. If not, run a snake through it. If it's CI, it would depend on how old the structure is as the p-trap may not have been replaced 14-years ago. A CI one could last many decades...the operative word is could.
    Nov 2010
    My drain is ABS (black plastic tube). It's fairly cheap and easy to change.
    Cutting the prying the subfloor is the bulk of the work.
    Is it worth the effort?
    If the drain is where you want it and properly vented, I see no big reason to change it.
  1. P trap problem, change from single to double bowl
    By pghsebring in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-05-2011, 06:40 PM
  2. P-Trap into floor drain? Or is that an S-Trap? (and not good)
    By bretm1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2011, 07:19 AM
  3. 3" trap arm - horizontal drain height change
    By Rousifier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-19-2011, 08:31 PM
  4. Lav trap on larger trap arm: actual problem?
    By dave148 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2008, 07:34 AM
  5. Replace S-trap with P-trap or chicago loop?
    By staceyneil in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-05-2007, 08:06 AM
