Thread: assembling ABS pipes
    DIY Junior Member filipi's Avatar
    Dec 2012
    California
    Default assembling ABS pipes
    Hello everyone
    I was assembling and gluing ABS pipes and fittings together, and one of the pipe didn't bottom out in the fitting , may be by 1/4". I guess I didn't push hard enough and it dried before I could do anything about it.
    Is that still acceptable if not leaking or shall I cut that section and redo it ?
    Thanks.
    This obviously for a drain line. Drains are never under pressure, so I think your OK. Just a tip that maybe you haven't picked up on. When connecting ABS or PVC just apply the solvent to one joint at a time. A good swab around the inside of the fitting and a good swipe around the outside of the pipe end. Then insert the pipe into the fitting with a twisting motion as well as pushing. Then hold the joint together for a few seconds so the pipe won't push away from the bottom of the fitting. All that said, I'd bet there are lots of joints that are working just fine that did not get all of the above done to them.
    Nov 2006
    For myself, that could depend upon where it is. The chance of it ever coming apart is pretty slim, but drain hubs (fittings) tend to be short and I would likely fix it if it were inside my house and being stressed in any way that might try to pull it apart.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    Default joint
    If there were any problem with your joint, it would be the gap in the flow line, but a 1/4" is not enough to worry about. The joint is not going to come apart because of that small gap. In fact, the gap could be 1" and it would still not come apart.
  1. Witching for pipes Video, this is how you find underground pipes.
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-16-2010, 11:46 AM
  2. Old pipes
    By Nettlewarbler in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-03-2009, 07:13 AM
  3. Air in pipes
    By Choral in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-30-2007, 06:42 AM
  4. pipes
    By pman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2006, 11:13 AM
  5. Air in Pipes
    By davidcohen7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-15-2005, 06:31 AM
