Results 1 to 6 of 6
Thread: Installing Kitchen faucet into single hole granite.
    DIY Member thinkly's Avatar
    May 2008
    Kansas
    Default Installing Kitchen faucet into single hole granite.
    I am getting ready to install a new Moen faucet into our granite counter top. The faucet comes with a plastic (looks like to me) gasket that sits between the faucet and the counter. The instructions say nothing about using putty or silicone, they just show the gasket. I called Moen and talked to a gal that said not to use anything but the gasket but I'm not sure where she pulled the answer out of.
    Should I follow her advice or am I headed for trouble?
    Here is a link to the faucet install video: http://www.moen.com/flv-embed?src=/s...640&height=360
    Jan 2008
    The faucet normally would not require any additional sealing. The drain is what gets silicone or plumber's putty.
    May 2008
    Kansas
    I understand that. I have just never installed a faucet without some form of sealant around the housing/counter interface.
    When a plastic or nylon seal is provided, I use that. I rarely would consider using putty, and not on granite anyway.
    Default sealant
    These days, most faucets come with a seal of some kind so you do not need any additional silicone or putty.
    DIY Junior Member AlexLinus's Avatar
    Oct 2013
    I am an home designer. Washington
    Lightbulb
    Yeah, modern day faucets already come with ready to install seals with them, hence no need to worry about that. Yeah people tend to feel skeptic about it when they use it for the first time (telling this from my personal experience) but they turn out to be pretty well. Go ahead, do that pending job and have your peace of mind. I recently installed new kitchen cabinets that I purchased online from the rta store and had a very good experience doing the task which removed most of my beliefs about home improvements. Faucets are a little tricky thing but believe me it's easier done than said.
    Thinking Ideas...
  1. Installing faucet on new granite.
    By thinkly in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2013, 03:50 PM
  2. Need a reliable three hole kitchen faucet
    By E. Williams in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2013, 06:39 AM
  3. size hole for single hole faucet
    By bobbieK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2009, 01:31 PM
  4. Moen Kitchen Faucet Leaking on 3 Hole Sink
    By kornbln in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2008, 04:01 AM
  5. Help with Moen Single Hole Faucet
    By sharonv in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2006, 12:54 PM
