Results 1 to 7 of 7
Thread: Insulate undersized supply pipes to quiet them?
    DIY Junior Member Buttonsrtoys's Avatar
    Nov 2012
    Nova Scotia, Canada
    Default Insulate undersized supply pipes to quiet them?
    I'm remodeling and ripped out all my 1" plaster and am replacing with 1/2" gypsum board. Because of this, I'm realizing how loud my supply pipes are. In particular, when a toilet or tub fills. It's a 60 y.o. house and the pipe's are 1/2" throughout, so undersized. The the pressure and supply are both fine, it's just the noise that's the problem. I don't have it in me to rip them out and am wondering if wrapping them with insulation would help. If so, is there a particular size or type? Any other advise would be much appreciated.
    Default noise
    The noise will be transmitted through the entire system, so insulation will probably not have a significant effect on quieting them.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    You might get better results by way of installing a pressure reducing valve, since lower pressure equals lower flows and quieter plumbing.
    Nov 2012
    Nova Scotia, Canada
    Thanks HJ. Due to my ongoing reno, I have access to 90% of the system (it's mostly in my exposed basement ceiling and one open wet wall). Do you think I'd still see negligible results?
    Nov 2012
    Nova Scotia, Canada
    Quote Originally Posted by Wet_Boots View Post
    I'd like that idea. Thanks!
    Note that a PRV usually needs a thermal expansion tank installed also. Neither of these are extremely expensive nor are they difficult to install.
    Default Prv
    Lower pressure equals lower flows, which is the same as lower volume, so your shower output may be adversely affected. The real problem is that your entire system is undersized, and you are trying to fix it by "putting band aids on a broken leg".
  1. What's the best way to insulate copper pipes?
    By stark in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-17-2013, 11:17 AM
  2. Pex and Condensation - to insulate or not to insulate?
    By techinstructor in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2011, 07:51 AM
  3. To insulate or not to insulate a basement bathroom??
    By mrmichaeljmoore in forum Remodel Forum & Blog
    Last Post: 04-05-2010, 02:12 PM
  4. Insulate Pipes OUTSIDE wall and Kerdi around shower valve
    By rsmith99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2008, 09:28 PM
  5. insulate water pipes
    By garyeuren@qwest.net in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-01-2006, 11:01 AM
