shower vs tub drainage
beck
louisiana
I am thinking about converting my 32" shower into a raised 55" tub (older model, could have had clawfeet but now sitting on blocks). The tub is currently in an old house and I would have to remove it from said home. I have enough room to place the tub after demo to the cabinets beside the shower stall. I was wondering what all would be needed to do this conversion.
I have been told two different stories regarding the drain. First one would be that the concrete would need to be drilled into and removed to move the location of the drain and place it at angle to ensure proper drainage.
The second story is that since it is a raised tub instead of a drop in that it would be okay to leave the drain where it is and run the plumbing with a 45 angle for drainage.
I am also wondering how I would have the tub elevated without having clawfeet attached, if at all possible. Would building a platform be appropriate or just a waste of time and money?
Any input would be greatly appreciated! Please note that this would be a DYI project.
drain
How you run the drain depends on how many problems you want to have with it over the ensuing years. If you want as few as possible, break the concrete and position the drain, and trap at the end of the tub, but even then you could do it incorrectly and still create problems for yourself. This could be one of those things that "if you have to ask HOW to do it, maybe you shouldn't be doing it yourself". You may only have two options as far as actually installing the tub. Either find legs or build a platform and hang the tub by its rim.
