Results 1 to 7 of 7
Thread: Septic Tank Periodic Treatment
    DIY Junior Member dano710's Avatar
    Jun 2013
    Tehachapi, California
    Default Septic Tank Periodic Treatment
    I just installed 2 Toto Drake II toilets in my home and wondered if the Home Depot Septic Tank treatments from ZEP or others will harm the Sanagloss coating?
    Mar 2011
    Houston, TX
    Quote Originally Posted by dano710 View Post
    You put it in and flush it. Do not leave it in the bowl.
    I use plain Yeast, and some say none of that stuff works.
    What kind of Septic Tank treatments is HD selling ?
    Kroger is cheaper.
    Jun 2013
    Kroger is cheaper.
    Ha...I understand it needs to be flushed, but the temporary time the treatment is there...I wanted to make sure it wasn't harmful to duragloss. It is made by ZEP, and it is a package of 6 bags. I dont know if it chemically, or from an abrasive standpoint would be bad for the toilet....thought you might know.
    This is my first Toto...and want to take care of it well.
    Zep Septi-Tabs Septic System Treatment
    CAUSES EYE IRRITATION.
    MAY BE HARMFUL IF SWALLOWED.
    *Hazard Determination System (HDS): Health, Flammability, Reactivity
    Acute Effects
    Eyes
    Skin
    Inhalation
    Ingestion
    Routes of Entry Eye contact. Ingestion.
    May cause eye irritation. Exposure unlikely in this form.
    May cause allergic reactions in certain individuals.
    Non-irritating under conditions of use.
    May be harmful if swallowed. May irritate digestive tract.
    What kind of stuff is this?
    I normally use Bio-Clean
    You can eat that stuff.
    DIY Junior Member GeorgeCT's Avatar
    Apr 2011
    Name of Hazardous Ingredients (From Material Safety Data Sheet)
    http://www.homedepot.com/catalog/pdf...fc03054932.pdf
    CITRIC ACID; 2-hydroxy-1,2,3-propanetricarboxylic acid 77-92-9 45 - 55
    SODIUM BICARBONATE; Monosodium Carbonate; Baking Soda 144-55-8 45 - 55
    VIABLE BACTERIAL CULTURES; a variety of strains of bacteria
    Mar 2011
    Houston, TX
    Quote Originally Posted by GeorgeCT View Post
    That is kind of a strange makeup.
    I think You would want to flush it quick a time or two, or maybe run it down the sink.
    That stuff may kill roots also. Guess that may be what the acid is about.
    I used Rid-X for many years, when it came in liquid I stopped using it.
    If you Flush some yeast, it gets the brew cooking, and is safe. But it does make some CO2 gas.
    Have Fun.
    Mar 2011
    Long Island, NY
    Have Fun.
    Don, for what its worth, I've been using that same Zep stuff for years. It is not expensive at all; probably much cheaper than the yeasr I've seen in the supermarket. Zep is 9 bucks or so for 6 bags. One day, I'll do a test with 2 buckets of water with toilet paper and dog poop. One bucket will have the Zep, and the other , not. After a couple of weeks or so, I'll see if I can see or smell any difference. That should be fun? What's with the freezing cursor thing here again???
  1. Replies: 0
    Last Post: 02-14-2013, 06:34 AM
  2. Connect septic pipe to septic tank????
    By Blueboat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-28-2012, 10:10 AM
  3. Periodic Sediment Problem in Well
    By techinstructor in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-13-2011, 09:03 AM
  4. septic tank
    By HAMLIN in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-06-2009, 05:50 AM
  5. Septic gas belching past full p-traps/ Septic tank drainfield failing? Venting issue?
    By ryan100 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2008, 06:49 PM
