Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Ball valve stem leak
  1. #16
    DIY Junior Member DanielV's Avatar
    Jan 2012
    Lakewood Colorado
    I'm a complete amateur but this subject seems somewhat related to my problem.
    I have a Legend S-1100 Ball Valve that shuts the water off to the sprinkler system on the opposite side of the wall outside.
    The problem is there is a leak through the valve itself, as when I open that little brass cap right next to the valve (to let the water drain out of the pipe between the valve and the back flow preventer valve outside), it continues to drip.
    So, it's not shutting off completely, allowing a small amount of water (a drip about every 5 seconds) to flow through the pipe.
    Unfortunately this ball valve has no packing nut! Nothing to tighten except the nut that holds the handle on and I have no idea what to do now.
    Is it too old? Do I need to replace it completely? I don't have all the tools to do that, so I was hoping there was something I'm missing.
    I'd take a picture of the thing but my camera is broken too.
  2. #17
    Jan 2012
    Lakewood Colorado
    Ah, thanks for the image Terry.
    So, I guess I'll just have to replace the whole thing, then.
  3. #18
    Have you pulled the handle and looked to see if there is a bonnet nut under there somewhere?
    From deleted post above. Terry
    If I'm understanding his observation, it's not leaking around the handle, it's leaking through the seal on the valve itself as evidenced by there being water coming out the drain hole. If so, then the valve itself is worn out or defective.
    But, if the backflow preventer wasn't working properly, any water in the sprinkler system could drain back and have a drip there for quite awhile unless you blew out the lines with an air compressor.
  4. #19
    Jan 2012
    Lakewood Colorado
    For some reason I do not see Terry's reply in the thread, so I didn't know he asked that question.
    Sorry about that.
    Yes, it's leaking out of the drain hole, not the handle (though I did remove the handle and there is absolutely nothing to adjust or grab onto under there).
    It's interesting to learn that, while ball valves may be more reliable, they are pretty much unrepairable when they do go, as compared to other valve types.
    Is this a correct assumption?
    I suppose if I were more handy this wouldn't be so much of an issue
    Thanks for the help!
    edit
    btw, it is a brand new Febco back flow preventer, and I did notice last year that the drip was still happening even after blowing out the lines, so it must be the shut off valve.
  5. #20
    Overheating it during installation could ruin the seals.
  1. Ball valve stem leak
    By jsadik in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2012, 04:03 PM
  2. Leak at ball valve nut
    By spta97 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-25-2009, 05:05 PM
  3. Question on Bathtub Valve Stem Leak
    By moeronn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-02-2008, 07:28 PM
  4. new ball valve leaks at stem
    By Kevin G in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-28-2008, 11:10 AM
  5. air leak at valve stem on captive air tank
    By Timmy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-25-2007, 07:40 AM
