Results 1 to 2 of 2
Thread: Grounding for Water Heater
    DIY Junior Member bob_cville's Avatar
    Feb 2008
    Virginia
    Default Grounding for Water Heater
    Greetings All,
    I'm replacing a failed electric water heater that was connected with 10-2 romex wire without ground. The inspector says that since it was that way before it is grandfathered in but it seems to me that it would be safer if it was grounded. Immediately above the water heater there is a large (#6 or #8) solid wire clamped to the cold water pipe which runs back to the grounding bar on the main panel. Is it a good idea to connect a wire from the ground screw on the water heater to the clamp on the water pipe? If so what gauge wire? If not, what should I do? Just be happy that the inspector said it was grandfathered? Run a new 10-2 with ground all the way back to the panel?
    Thanks in advance for advice on this.
    -Bob
    Default ground
    Ideally, that ground should NEVER conduct any electricity, but to be safe a #10 or # 12 ground wire will be sufficient connected to the existing ground clamp.
  1. Replies: 0
    Last Post: 11-19-2012, 10:37 PM
  2. Grounding Whirlpool Tub Motor and Heater - Bonding Panel to Electric Water Heater
    By chuck b in forum Electrical Forum discussion & Blog
    Last Post: 02-06-2012, 09:01 AM
  3. grounding ?
    By web_surfer in forum Electrical Forum discussion & Blog
    Last Post: 11-27-2009, 11:38 AM
  4. Grounding cold water pipe
    By DaveU in forum Electrical Forum discussion & Blog
    Last Post: 01-29-2008, 04:36 PM
  5. Water Pressure and Hot Water Heater Grounding
    By barrylott in forum Shower & bathtub Forum & Blog
    Last Post: 04-07-2006, 08:02 AM
