Thread: Pipe freeze protection cable
    DIY Junior Member dave1909's Avatar
    May 2013
    Montreal
    Default Pipe freeze protection cable
    Hello ,
    I need some advice,
    I will install a pipe freeze protection cable on my pipe.I will like to know your opinion on the best place to put the cable heat thermostat.In the installation instruction we can read" the thermostat should be placed on the coldest end of the pipe". The problem is that if I put the thermostat
    where my pipe froze last year (see the picture to know where) ... this portion of the pipe will not be heat , so this portion of the pipe will retain cold and never been heat...
    so my pipe had chance to freeze again next winter.
    I'm confused .... where is the best place to put the thermostat if you look at my plan?
    Nov 2006
    The spot you have marked might be the lowest part that froze, but everything above that would have frozen before that even though it might have thawed before you began digging down to the part that was still frozen. Placing your thermostat at the frost line (the deepest spot where the ground freezes) would assure the lowest possible spot could not freeze, but freezing would actually begin above that point and work its way down...and I think that is what you are concerned about (just as I would be). So, I would place the thermostsat just above ground level (where freezing air would find it right away) and then be sure the heat tape began at the frost line and went all the way to the floor with pipe and tape all nicely wrapped with insulation.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    Keep in mind that insulation alone will not keep the pipes from freezing. Insulation around the heat tape will slow the heat loss from the tape. That's why you need both heat tape and insulation.
    Not all heat tape can be buried in insulation...read the instructions carefully, or risk either burning out the cable or burning down the trailer.
  1. pipe protection
    By jetlag in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2010, 08:54 AM
  2. PEX freeze protection
    By Steve-WA in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2009, 06:46 AM
  3. Sump Pump Discharge - freeze protection
    By norpellc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-21-2008, 06:28 PM
  4. Pipes & Meter freeze protection question
    By yds in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-25-2007, 09:12 AM
  5. Riser Freeze Protection
    By kenbect in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2007, 01:42 PM
