Results 1 to 9 of 9
Thread: water heater to utility sink
    DIY Junior Member cmcoffey13's Avatar
    May 2013
    Madison
    Default water heater to utility sink
    I have an existing mini water heater that is on a "shelf" about 12 feet in the air. I'm hoping to install a utility sink underneath it. Currently the water heater is running to a bathroom. How do I run the lines to the sink? Do they need to be cut and redirected with elbows? I've never done any plumbing except to replace a toilet. I got a $1000 quote from a plumber and am not willing to pay that.
    Nov 2006
    If the cold line coming to the water heater is at least 1/2", you should able to add tees and elbows or whatever and bring cold and hot water down to your new sink without robbing all the flow to the bathroom...but you might still experience a bit of disruption at the bath or shower whenever someone uses the new sink at the same time. What kind of lines do you have at the heater?
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    May 2013
    Madison
    It's copper pipe. Is that what you mean?
    I'm hoping for perhaps a step by step idea on how to do this. I would like to work on it today. There is no shower. Just sink and toilet.
    Nov 2006
    Quote Originally Posted by cmcoffey13 View Post
    Yes.
    How does your water heater happen to be "on a 'shelf' about 12 feet in the air", and are all your plumbing lines up there also? A picture or two could be helpful here, and what do you have available for a drain line for the new sink?
    May 2013
    Madison
    It was there, not sure why. I have a pic but can't figure out how to send it to you...
    Also I think the heater is up there for gravity to help??lol
    It doesn't matter where the water heater is.
    An fixture can have water, if you supply it with piping or tubing. Any hardware store will pipe and fittings. It's a simple matter to cut in tees from the water heater and run them to the fixture. At the fixture, it's a good idea to have shutoffs. If you are using 1/2" pipe, you will need 1/2" x 3/8 compression, the most used size. The faucet may come with supplies or you may need to pick up lav supplies for it.
    Feb 2005
    Default mickey mouse job
    there is a thousand ways to rig this up without paying someone $1000...
    why fool around with the water heater when you could probably do it all under the vanity??.
    you could probably just tie onto the 3/8th lines under your vanity feeding the faucet if they are close enough to your new sink... all you would need is 2 3/8 compression tees and the 3/8th copper to run
    it to the new sink location.... its not brain surgery....
    the drain line is another story... hack saw and some glue
    remember that hot goes on the left and cold goes on the right...
    so what the hell have you been up to Terry??
    still dateing the hot chick??.
    Hi Mark,
    I was just telling Sue about you this afternoon on our walk by the lake and how you sold me http://waterheatersseattle.com/
    I'm thinking more water heaters is a good thing.
    Feb 2005
    Default looking good for winter
    Yea terry, she is looking good for winter time
    but these snow bunny pictures are not cutting it
    its summer time
    now you got to get her down on the beach and then post some
    swim suit shots...
    you go guy......
  1. Can bath sink and utility sink drain into 1.5"...PHOTOS
    By Hammerlane in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-16-2012, 01:02 PM
  2. Can I tie my bathroom sink and utility sink drains together? As well as vent?
    By vinceliberto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2010, 06:02 AM
  3. Utility problems - possible water heater?
    By kbbeale in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-21-2010, 09:24 AM
  4. Basement remodel - bar sink, utility sink - design
    By jbrinker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-27-2009, 09:14 AM
  5. Utility Sink - How to tie into existing water line
    By bock in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-03-2008, 11:03 AM
