Thread: Bath tub alcove
    DIY Senior Member DougB's Avatar
    Jun 2010
    Minneapolis - Land of 10,000 taxes
    Default Bath tub alcove
    I'm building the end wall of an alcove for a drop-in tub. How much wider than the tub do you think I should make the wall? I was thinking about 3"
    I was figuring this would allow for a shower rod.
    If a hammer won't fix it, it's an electrical problem.
    The end of a shower rod often (it does not have to) lines up nearly with the inside of the tub opening, so that would be more than sufficient. Some people like it to be further out, but there are two ways to accommodate that: have a decent overlap, or use a curved shower rod. For aesthetic reasons, it is common to make that wide enough so your trim piece can continue to the floor whole, so the width would depend on the tile and trim you select (assuming you're going to use a trim, maybe a bullnose, there). FWIW, if the tub you want is available with tiling flanges, you're much better off using that. I bring this up because you mentioned shower. Unless you are going to use a circular shower curtain rod, you need to waterproof the tub edges, and while possible, it is MUCH better to buy the tub with an integrated tiling flange - your chances of a leak there are much diminished.
    Jun 2010
    I've researched the tubs. It seems HydroSystems makes some pretty pratical tubs. I'm looking at the Lacy. You can get it with the tile flange molded right in.
    It's a good point about the bull nose width.
  1. Sub-Floor under Alcove Tub
    By weekend_warrior in forum Shower & bathtub Forum & Blog
    Last Post: 08-08-2012, 09:49 AM
  2. New tub for a 29X60 alcove
    By willy65000 in forum Shower & bathtub Forum & Blog
    Last Post: 03-11-2011, 03:55 PM
  3. Drop in tub in alcove
    By Marty53 in forum Shower & bathtub Forum & Blog
    Last Post: 04-10-2009, 06:47 AM
  4. Alcove tub rough in
    By dupree495 in forum Shower & bathtub Forum & Blog
    Last Post: 01-02-2009, 06:05 PM
  5. install alcove CI tub
    By geandham in forum Shower & bathtub Forum & Blog
    Last Post: 01-06-2008, 10:39 AM
