Thread: New Bathroom Faucet Water Connections
    DIY Junior Member Ecooper77's Avatar
    May 2013
    Dallas
    Default New Bathroom Faucet Water Connections
    Hi guys! So, over the weekend I went in to relace my bathroom faucet. I got all the old stuff out then went to Lowe's to get the water supply lines (that I'd naively assumed would come with the new faucet). I get home and the new supply lines don't fit the old (1955) copper water valve connections. Is there some sort of connector that will hook the new, braided water lines to the old copper connector heads? I've attached some images for clarity. Your help is much appreciated!
    Name:  old and new faucets.jpg
Size:  98.2 KBName:  existing connection.jpg
    Aug 2009
    South*East
    I would replace the valves. The one's you have are for a flair connection.
    John
    Anytime you're refreshing the valve, it's a good idea to replace the shutoff valves as well. Those look like they are soldered on, but there appears to be enough length to just cut them off and use a compression valve (depends on the brand but most require about 1", plus some extra if you add new eschutions). You will need to polish off all of the paint or whatever is there down to bright copper to get a compression valve to seal properly. Or, once you've got it cleaned up, you could solder on new ones. While you have things apart, you can get new eschutions to slide over the pipe stub for a couple of bucks more.
    May 2013
    Dallas
    thanks for your help guys!
  1. Trouble replacing faucet in bathroom - Corrugated tubing lav connections?
    By WDavid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-11-2012, 04:53 AM
  2. No hot or cold water from bathroom faucet
    By Canuck Fan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-19-2010, 05:59 AM
  3. O-ring supply connections on lavatory faucet -- convert from braided hose to 3/8 tube
    By dujour in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2010, 08:05 AM
  4. no hot water when using the bathroom faucet
    By miss mary in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-05-2007, 06:47 PM
  5. No water from bathroom faucet
    By spike808 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2006, 07:13 PM
