Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: 35+ PSI boiler pressure. Have gone through the usual checks.
  1. #16
    Nov 2010
    Maine
    Fire the boiler up. It makes no difference what calls the burner. There is no tester made that will pinpoint the leak. The boiler already has a pressure gauge on it.
  2. #17
    DIY Junior Member bluefleetwood's Avatar
    May 2013
    Setauket, NY
    Thanks Tom,
    PRV Still leaking, Pressure in boiler still not exceeding 28 PSI.
  3. #18
    Nov 2010
    Maine
    Replace the indirect. The pressure won't go much higher in the boiler because you have a very small leak in the indirect coil and the relief valve is leaking it off.
  4. #19
    May 2013
    Setauket, NY
    Thanks Guys,
    New Indirect Installed. Smaller Unit with same volume, Much more efficient. Boiler pressure remaining at 12PSI. Now to completely empty old one to get to supplier for refund.
    Again thank you all for your help!
  5. #20
    In the Trades lkgproducts@gmail.com's Avatar
    May 2013
    cleveland ohio
    HAVE YOU CHECK OUT www.appttestersllc.com or amazon.com just punch in appt testers. or ask @ your supply house or contact me toll free 855 808 lkg1(5541 and i will set you up.
    i am a plumber by trade and inventor of the ALL PURPOSE PRESSURE TESTERS & KITS LOUIS GIORDANO
  1. Boiler Pressure
    By Engine1 in forum Boiler Forum
    Last Post: 02-19-2012, 11:12 AM
  2. Boiler Pressure
    By tombstone in forum Boiler Forum
    Last Post: 12-12-2011, 08:47 AM
  3. Replies: 10
    Last Post: 10-24-2011, 05:52 PM
  4. Not your usual S-trap question
    By JenaK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-06-2011, 11:37 PM
  5. Boiler pressure
    By swcooper in forum HVAC Heating & Cooling
    Last Post: 03-31-2007, 10:29 AM
