Results 1 to 5 of 5
Thread: Building a P-trap
    DIY Member SH140's Avatar
    Jan 2013
    Vallejo, Ca.
    Default Building a P-trap
    Getting ready to install plumbing for new tub install, and wanted to know ahead of time if there are any limitations when installing the p-trap. I know that the standard trap is a fairly tight radius. If need be, could a trap be made with two 90o elbows with a straight connecting pipe at the bottom ? if so how long can connecting pipe be so that the trap still functions correctly? (1", 3", 12" ???) If not, is it because the trap operates more efficiently with a tight turn in a shorter length?
    Also, where there will be no access to the plumbing after the tub goes in, is it better to use only glued joints in the ABS plumbing?
    A longer run would be more inclined to gunk up.
    Glue joints are always better then slip joint where there is no access. In fact it's now a requirement.
    I've made traps using street medium 90 bends.
    Jan 2013
    Vallejo, Ca.
    I kinda thought that was the reason. Thanks
    I was wondering...does plastic pipe cement ever go bad? If it's still in a liquid state, is it still good to use. Mine is a few years old, but still looks OK.
    Plumber jimbo's Avatar
    If the can has ever been opened, it is questionable. The cement should be very "liquidy". Any signs of gel-like texure is a no-go.
    Jan 2013
    Vallejo, Ca.
    Thanks for the tip. Because the plumbing won't be accessible afterwards, I bought a new can. Better safe than sorry.
  1. P-Trap into floor drain? Or is that an S-Trap? (and not good)
    By bretm1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2011, 07:19 AM
  2. building-please help!
    By dreamhome in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-07-2009, 07:11 AM
  3. Information on Running a Frost Free Water Line from building to building
    By staysteady in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-14-2008, 10:07 AM
  4. Lav trap on larger trap arm: actual problem?
    By dave148 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2008, 07:34 AM
  5. Replace S-trap with P-trap or chicago loop?
    By staceyneil in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-05-2007, 08:06 AM
