Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: How do you center an offcentered shower drain
    DIY virgin taz1811's Avatar
    May 2013
    Washington DC
    Default How do you center an offcentered shower drain
    Just removed all the tile, 4 inches of cement, and the old shower liner and this is what I'm left with. Any ideas or suggestions on how to get this drain centered?
    The only way to do this is to move the walls! or crack some concrete and move the pipes. Or, leave it where it is. With a clamping drain, you'll either be building another conventional shower, or use a conversion drain and switch to something like Kerdi. Or, if you do end up moving it, just a drain for the system you choose. While it is nice to have the drain centered, it doesn't have to be - it must means the slope on the shorter wall will end up steeper (if you do it the way most people recommend it and have a level perimeter).
    Jul 2009
    North Vancouver, BC
    Post(s) removed by John Whipple
    May 2013
    Washington DC
    This is a shower in a basement that I demo'ed. So there is no pan, I'm assuming it's cemented into the house's foundation, and there is no slope. The drain is actually about an inch below all the concrete flooring. I was thinking about taking a circular saw with a diamond blade in an attempt to remove the foundation.
    Jul 2009
    North Vancouver, BC
    Default Noble Flex Flashing
    Concrete is not waterproof! Once you figure out where you want the drain, you really do need to put in a preslope then the waterproofing layer. If you use something like Kerdi, you do not need to add another mudbed on top of the liner, since Kerdi is the liner. You do need to choose the right drain, though, regardless of what you decide.
    May 2013
    Washington DC
    Progress....
    Jul 2009
    North Vancouver, BC
    May 2013
    Washington DC
    Quote Originally Posted by johnfrwhipple View Post
    Is that a Pipe Shooter bit on the drill?
    Now what? Are you going to bust some concrete? Wish I was doing demo today. Stuck in the office working the phone all day. Sucks. JW
    The drill is actually a Dremel. I used it to cut off the old drain.
    What's next you ask?....Not sure honestly. Should I take the circular saw and cut something like this?
    Name:  new drain.jpg
    I would take a sledge hammer to the floor, break out what is needed and then extend the horizonal waste line and install a new p-trap in the new location.
    I could almost do that quicker than I can type it.
    Well.............almost.
    You're getting there. The hole will need to be deeper.
    Jul 2009
    North Vancouver, BC
    May 2013
    Washington DC
    Those are water pressure fittings. There is no way a snake will pass though those.
    Move the entire p-trap in the ground, and have only a vertical pipe down to the p-trap.
    May 2013
    Washington DC
    Terry,
    Alright I took your advice and re did it. It was much more work than I expected, but it's coming together.
    Looking good!!!
  1. Desperate!!! Jacuzzi Tub Center Drain Removal?
    By debc in forum Shower & bathtub Forum & Blog
    Last Post: 05-09-2011, 07:23 AM
  2. Artist Center - Drain Line for Work Sink, Paintbrush Cleaning
    By jjohanson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2009, 10:49 AM
  3. Double vanity with single center drain?
    By MartinM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-14-2007, 07:13 AM
  4. Pop-up Sink Drain install - off center sink drain???
    By JeffH in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2006, 11:03 PM
  5. Center Drain tub
    By gieset in forum Shower & bathtub Forum & Blog
    Last Post: 04-29-2006, 07:02 AM
