Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: GreenSkin Flooring's Anti Fracture Membrane - Anti Wicking design by Devcom
  1. #16
    Jul 2009
    North Vancouver, BC
    Default GreenSkin Shear test over 1/2" rigid foam
    Post(s) removed by John Whipple
  2. #17
    Jul 2009
    North Vancouver, BC
    Default Green Skin Shear testing over Drywall
  3. #18
    Jul 2009
    North Vancouver, BC
    Default GreenSkin over tile vs 8+9
  4. #19
    Jul 2009
    North Vancouver, BC
    Default The uncoupling membrane show down
  5. #20
    Jul 2009
    North Vancouver, BC
    Default GreenSkin Shear Testing - First Round a Fail
  6. #21
    Over drywall and a cbu, you really need to wash the walls down to remove both the dust and to premoisten the boards...both of them can suck a lot of moisture out of the thinset quickly, and significantly affect the bond strength. Some porous tile can have problems with that, too. NOt an issue with a porcelain, but then getting it to stick well begs burning in a layer on the back.
  7. #22
    Jul 2009
    North Vancouver, BC
    Default GreenSkin and bond-breakers - effects on Shear Testing
  8. #23
    Jul 2009
    North Vancouver, BC
    Default GreenSkin Shear Testing - 2"x2" set over GreenSkin over Drywall Failed - 42.59 lbs
  1. Anti freeze
    By Stephen C in forum Tankless Water Heater Forum
    Last Post: 01-02-2012, 06:58 PM
  2. anti siphon faucet
    By capon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2009, 07:39 AM
  3. anti siphon faucet
    Last Post: 07-26-2009, 07:32 AM
  4. help! h2o shooting out of anti-siphon
    By iamasailor in forum Irrigation / Sprinkler Forum
    Last Post: 07-16-2006, 11:14 AM
  5. anti scald
    By Yersmay in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-11-2005, 07:21 AM
