Results 1 to 6 of 6
Thread: How to plug a shower hose with a decorative trim
    DIY Junior Member den2013's Avatar
    May 2013
    California
    Default How to plug a shower hose with a decorative trim
    Hi all,
    I urgently need ur help, as I made a major mistake to my shower. It's embarrassing to say it, so I keep it short.
    I need to close the the shower head . That can be done easily with a plug. But how do I cover the hole in the tile, so that it still looks nice.
    Is there any product for that all?
    Thanks all,
    Den
    Jul 2009
    North Vancouver, BC
    Perhaps you could have a plumber install a small cap to close down the supply line and then infill this area with a small amount of mortar. You might need a shot of spray foam first to fill in the voids and perhaps backer rod before that.
    Then you could install a robe hook or something like this.
    Why not just remove the tile in the affected area and do this part over. That would be the cleanest look.
    JW
    Quote Originally Posted by den2013 View Post
    Hi all,
    Thanks all,
    Den
    May 2013
    California
    Post
    Quote Originally Posted by johnfrwhipple View Post
    JW
    Thnx for quick reply John
    I'm going to open up the back wall,
    Move the pipe, then attach a hardy to cover the hole
    At the front, I will apply thin set n grout.
    Then cover the patch with shower bar
    Jul 2009
    North Vancouver, BC
    Maybe pre-attach some plywood to the the Hardy Board first so you can drive in some screws later when you mount the shower bar. Can you install a proper cleat between studs?
    Maybe your wife will want to hang from this new shower bar! If your lucky.
    Safety never takes a holiday.
    May 2013
    California
    Done, my wife is so happy to see it. But I told her not to pole-dance it.. Haha..
    Thanx John
    Jul 2009
    North Vancouver, BC
    ... But I told her not to pole-dance it.. Haha.....
    We need to talk. That is the worst advice I have heard online to date!!! lol
  1. Leaky factory plug in shower valve?
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-17-2012, 06:11 PM
  2. Plug for testing the pan liner in the shower base??
    By Designie in forum Shower & bathtub Forum & Blog
    Last Post: 02-04-2011, 05:47 AM
  3. To plug or not to plug into a GFCI outlet
    By DIY in forum Electrical Forum discussion & Blog
    Last Post: 04-15-2009, 04:13 PM
  4. Replacing Shower Trim
    By macd in forum Shower & bathtub Forum & Blog
    Last Post: 10-29-2007, 12:21 PM
  5. New shower trim wallplate doesn't cover shower wall hole
    By ax77 in forum Shower & bathtub Forum & Blog
    Last Post: 12-02-2006, 08:51 PM
