Results 1 to 5 of 5
Thread: LED pool light
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Default LED pool light
    Has anyone experience with LED pool lights?
    Currently expensive, but as with all LED technology, that is going to drop off.
    A friend wants to install:
    http://www.****.com/itm/L-E-D-Swimmi...3&cmd=ViewItem
    Me? The only reserve I have is that it costs about 4x of a conventional bulb.
    Opinions?
    I just replaced my dining room lights with LED's
    I got tired of replacing bulbs and knowing that I have five 40 watt bulbs on most of the day. They also do some dimming.
    Jan 2012
    Los Angeles, CA USA
    Oh, I have substantial experience with LEDs in recessed lights.
    If you are having difficulty with dimming, you may have a dated dimmer.
    Lutron currently has dimmers specifically only for incandescent and halogen, and another range specifically for compact fluorescent and LED.
    If in doubt, one might want to pull out the existing dimmer and look at the back of it.
    I have a new Lutron dimmer that's spec'ed for LED.
    I replaced that last year.
    It' dims, just not as much as the incandescent bulbs. Though the reason I dimmed those so low was to save power, and the LED's do that anyway.
    Default bulb
    quote; Me? The only reserve I have is that it costs about 4x of a conventional bulb. But it will last several times longer, although with the limited use many pool lights get, that may not be a factor.
  1. Swimming pool light
    By Homeownerinburb in forum Electrical Forum discussion & Blog
    Last Post: 06-19-2012, 05:48 PM
  2. DIY - Split receptacle to light switch and light fixture with 14/2?
    By AJM in forum Electrical Forum discussion & Blog
    Last Post: 11-24-2009, 04:36 PM
  3. pool pump
    By cavie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-05-2009, 08:32 AM
  4. pilot light wont stay light on furnace
    By possum in forum HVAC Heating & Cooling
    Last Post: 10-07-2008, 12:48 PM
  5. pool
    By Jim27 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2007, 04:44 AM
